ls6 intake
Old Apr 16, 2010 | 03:12 PM
z99ls1's Avatar
Restricted User
Default ls6 intake
Ok so I read up a little bit on the ls6 intake and have some questions.. I shouldn't have to alter anything, but the egr right? As long as I cut the bottom things off the ls6 intake I do not need the coolant pipes or rear coolant plugs right?
Old Apr 16, 2010 | 03:18 PM
brian_rs/ss's Avatar
if u have stock manifolds you will need egr block off plates, and yes taking out the ribs underneath will let it fit right over the stock coolant crossover.
Old Apr 16, 2010 | 03:25 PM
z99ls1's Avatar
Restricted User
Cool so all I need is the ls6 intake and egr block off plates right?
don't forget intake gaskets.
Old Apr 16, 2010 | 03:31 PM
z99ls1's Avatar
Restricted User
This lsx engine confuses me lol. I don't have any idea. So I will probably have to scrap off the old gasket ?
Old Apr 16, 2010 | 03:39 PM
no they are individual rubber crush gaskets. there are 8, 1 per port, then a throttle body gasket of the same style.
Old Apr 16, 2010 | 03:40 PM
http://www.summitracing.com/parts/FEL-MS92438/
there is a recess that the gaskets fit into.
Old Apr 16, 2010 | 03:43 PM
https://ls1tech.com/forums/generatio...old-video.html
Old Apr 16, 2010 | 03:51 PM
z99ls1's Avatar
Restricted User
Ahh good lol, I was hoping I thought right on that. I didn't want a mess and have to scrap all the crap off like I did the lt1
Old Apr 16, 2010 | 03:53 PM
z99ls1's Avatar
Restricted User
Angry
I found that fid earlier and cant watch it lol.. It freezes up like every 5 seconds on me and when I pause it, it makes me start the video over.
Old Apr 16, 2010 | 03:57 PM
hmmm works fine for me? you have an old computer or something? maybe needs updates?
Old Apr 16, 2010 | 03:58 PM
z99ls1's Avatar
Restricted User
Any tips on how to watch the vid lol ?
Old Apr 16, 2010 | 04:01 PM
well myspace uses adobe flash player, my first bet would be that you don't have flash updated on your computer.
Old Apr 16, 2010 | 04:04 PM
z99ls1's Avatar
Restricted User
No your right. I finnaly got it to work! I just have to pause it and let if buffer every now and than
Old Apr 16, 2010 | 04:07 PM
ok awesome. that vid should explain a lot.
Old Apr 17, 2010 | 12:28 AM
z99ls1's Avatar
Restricted User
The fuel rails and everthing bolts right up to the ls6 intake right?
Old Apr 17, 2010 | 12:57 AM
yessir.
Old Apr 17, 2010 | 02:36 AM
z99ls1's Avatar
Restricted User
Ok so now im seeing that people are breaking there oil presure sending unit. How do I make sure that I do not break mine?
Old Apr 17, 2010 | 02:38 AM
98PurpleT/A's Avatar
You need to guy the hose that goes to the brake booster carefully around it, dont yank
Old Apr 17, 2010 | 10:41 AM
Paul Bell's Avatar
That's MISTER MODERATOR
If your car has an EGR valve, eliminating it will cause the PCM to set a code. It'll see it as "missing".
