big fitment problem after header install... has this happened to anyone else?? *pics*
Old Apr 18, 2010 | 06:09 PM
brandon_01_ta's Avatar
Default big fitment problem after header install... has this happened to anyone else?? *pics*
had my headers/y-pipe installed and noticed a horrible banging, rattling, and alot of vibration. it felt and sounded like it was coming from the drivers side header and not the y-pipe. after taking it to a shop and getting it on the lift i realized it's not the y pipe banging it's the drivers side header is resting up against the control arm (i think that's what its called... sorry) but anyway u can see in the pics how its actually resting against it... the passenger side isnt touching but theres about a quarter inch gap in spacing.... anybody else ever seen this and is there anything at all i can do about it?? i bout can't stand to drive the car... i know the car was in an accident or two with some front in damage before i owned the car. i'm afraid that has something to do with the fitment... anyway please give me your advice. thanks
Attached Thumbnails big fitment problem after header install... has this happened to anyone else?? *pics*-header1.jpg   big fitment problem after header install... has this happened to anyone else?? *pics*-header2.jpg   big fitment problem after header install... has this happened to anyone else?? *pics*-header3.jpg
Old Apr 18, 2010 | 07:06 PM
jsut's Avatar
hot rod style, hammer it in till it clears, thats what i did on my truck to fit camaro headers to fit, works all the time
Old Apr 18, 2010 | 07:13 PM
bww3588's Avatar
its typical for that header to hit the k-member. either grind the k-member, or dent the header tube.
Old Apr 18, 2010 | 07:39 PM
wisker27's Avatar
I installed Pacesetter LT headers on mine and i have plenty of clarence, no issues.
Old Apr 18, 2010 | 07:53 PM
yeah i had pacesetters on my last ws6 and there was plenty of clearence.... these are hooker headers and on a different car.. kinda wish i had gone with pacesetters.
i really dont want to have to purposely dent the tubes so i may try to grind down the k-member first and see how much clearence that gives me..... any reason i shouldnt mess with the k-member or is that what i should try first??
Old Apr 18, 2010 | 09:08 PM
sjsingle1's Avatar
poly motor mounts......if you still have stockers it will sit low......and have a frame shop measure your frame
Old Apr 18, 2010 | 09:10 PM
sjsingle1's Avatar
TSP LT.......poly MM
Old Apr 18, 2010 | 10:00 PM
so you think poly mm would fix this??
and dumb question but would i have to completely take off the headers and Y to do a poly mm install? i'd hate to pay my mechanic again to take them off and put them back on
Old Apr 18, 2010 | 11:59 PM
sjsingle1's Avatar
if you are paying some 1......i am sure it can get mighty expensive....i think the MM can be taken out from the front..........remove ALT and A/C....but i did mine when i did my headers.......i am sure the polys raised me up a bit....the stockers were sagging big time......i have very little clearance at the collector on the drivers side........but with the polys they will never move.......glad you got the TSP ORY to fit.....mine did not
Old Apr 19, 2010 | 08:11 PM
i'm gonna check with my mechanic to see how much he would charge me for a poly mm install but i have a feeling i'm gonna end up just purposely denting the header tube... i'd hate to do that but other than hurting exhaust flow a little bit can anyone give me a good reason not to do that?
Old Apr 19, 2010 | 09:51 PM
sjsingle1's Avatar
dimple the tube and grind on the K
Old Apr 19, 2010 | 09:55 PM
Z28_LT1's Avatar
Poly motormounts for the win.
