Idle high right after bbk tb install
I believe the throttle cable was at proper position, it has a hole about 3/16ths drilled in the TB blade, which I was wondering if that would do it.
Its a used TB and came out of a bolt on big cam LS1
I didnt let it run too long just about a min and then down the street and back, do I need to let it idle for awhile to learn the new tb?
by the way im running open LT headers right now if that matters at all and stock cam.
Pic is of the hole in the TB blade.
have you tired to loosen the idle screw on side to where it closes the TB more.
I also only put on 1 of the throttle cables, the one that is controlled by the gas pedal.
the other is just cruise control right? that needs adjusted before it can go on.
I'd expoxy it like above mentioned or maybe weld it for peace of mind also port that thing.
wonder if a little bolt and nut through would disrupt airflow much.
So there is not supposed to be a hole at all? your just supposed to adjust it open a little bit?
