BG Ram Air
Oh yeah...the rivets are super easy to do. I removed my rear baffle about a month ago. It literally took longer to get the drill and extension cord setup than it did removing all the rivets!
It looks like these pieces came straight from GM!The hardest part about the install is removing the front baffles. They're glued on there pretty good but a short wide screwdrive made quick work.
I'm going to head out for a little spin in a little while.....on the highway of course!!!
I'll update this when I get back!
Three reasons why I chose this mod:
1)The shortest most direct path for air should net the most air moved. In the BGRA's case, the air only has to go 6" or less to the inlet of the airbox. Nothing is more direct than that besides removing the hood!
2)I would guess that on a hot summer Florida day, where the pavement is 120 degrees....that the air would be cooler 2' above the surface than 8" above it (like the FTRA). I've seen guys on here saying their IAT is 40 degrees cooler since adding the BGRA. The air won't heat up until it's inside of the airbox....cooler air = denser air = more power.
3)Nothing like having a 'True' Ram Air hood! The kit actually funnels the air from the corners of the nostrils towards the center. At high speeds this will create a slight 'pressurization'.
This is just my opinion of course.
I just took the car out for some 'spirited driving'.
Holy CRAP!!! You get above 100 and the car pulls much harder than before...it was pulling so hard it actually scared me a little because I'm not used to that kind of pull.
I didn't feel much difference under 70.
I think I'm heading to the track this Wednesday.....we'll see what she does this time around. I'll let you all know what I run.
I was going to build my own functional Ram Air, I researched the materials and measured...etc, etc. But...I could never have built anything that would have matched the quality and fitment of the BGRA kit. It is truly a 'Cold Air' intake.
The SSRA and FTRA are great kits as well. Like I said....if you have a regular T/A or Camaro...I'd definitely go with one of those kits....probably one made out of plastic and not metal. Less heat soak.
Now...if you're thinking of the typical CAI that you see in Honda's and such....most of those are complete garbage as they are made of aluminum...a tube that stretches all the way across the engine bay. Think about it....aluminum is an excellent conductor of heat...and there is air passing through this tube. So even if the intake/filter is in the fender well....you're doing nothing but heating up the air all the way to the intake. hot air = less power.
Anyone?
