Super Victor vs Victor Jr.
combo:
11.5:1 370
PRC stage 2.5 ls6 heads
msd6010
232/240 .595/.608 112+4 (i know it's not optimized for carb setup, will be replaced this winter for a better carb cam)
1 3/4" primary longtubes (header selection is limited, pretty much the only thing available for a thirdgen camaro)
44-4800 converter (not purchased yet)
4.11 gears, 28" tall drag radials.
3200lbs
the goals are 6.99 and 10.99 on motor. do you think the Vic Jr. can get me there or do i need the Super Vic?
plus when you spend the time to have it hand ported the the super will be a great intake when done. The jr victor will still be a ok intake when hand ported and needs alot of work and doenst have enough metal to make it great.
The quality of the intake that comes out greatly depends on the porter. I have some TRICK vic jr intakes that would be flow better than a ton of supers. But ya your talking about spending some serious coin on stuff like that. Much more than the simple cost of the intake itself.
From a simpleton perspective. i was told this sort of shoulder isnt very detrimental and can actually be beneficial if ported correctly.
I had a quick talk about this with a friend who ports. I may have misunderstood.
Hopefully some one more knowledgeable will chime in.
b
ok i agree simply cause that was funny and in this case its not that big of a deal.
