SLP Powerflo??
Old May 12, 2010 | 11:55 PM
doomsdaymachine's Avatar
Originally Posted by Detoxx03
Well obviously you won't really lose your sanity but the lm's are very annoying after awhile.
since i belive you have one detoxx
whats the size inlet and outlet of the slp powerflo, 3'' ?
i was thinkin of buying it at summit but dam $300, can i use it with my custom made 3 inch pipes since also already have new tips
Old May 13, 2010 | 01:33 AM
pir7tr's Avatar
They are not 3". The inlet and outlet are 2.5"
Old May 13, 2010 | 06:03 PM
99canadahawk's Avatar
Cool then I think I`m going to order the Powerflow with the 4 inch tips this weekend , does anyone have pic`s of a T/A with these tip`s ???
Old May 26, 2010 | 01:10 PM
98RedBird's Avatar
I would be interested in seeing this as well.
Old May 26, 2010 | 07:07 PM
Your lucky I just recived my exhaust in the mail tonight , so hopefully I`ll have it on this weekend .
Here are some pic`s of the tips .
Old May 27, 2010 | 04:50 PM
98RedBird's Avatar
That actually looks pretty slick. You'll have to post up some sound clips as well
Old May 27, 2010 | 05:56 PM
Black 99 Bird's Avatar
So is it a significant drop in loudness? Just want my LM1 quieter.
Old May 27, 2010 | 07:48 PM
Sure I`ll post some more pic`s with a sound clip , hopefully this weekend !
( just as long as I can get the old system out )
Old May 27, 2010 | 07:53 PM
BTW , for those of you that have this system on your car`s how hard was it to install ?? & is there anything I should be aware of ?
Old May 27, 2010 | 11:51 PM
Thule's Avatar
i have a H/C/I car w/ LM1-ory.. and its insanely loud at any speed or any anything.. people run a away when i drive pass.. it does sound good in a mad way.. but need to be toned down,
i got the LM2 muffler ready to install and was thinking of the powerflow
we need a soundclip
Old May 28, 2010 | 12:25 AM
Detoxx03's Avatar
Not sure cause I have the corsa clones on my car
Yes best option to make it sane
Old May 29, 2010 | 09:45 AM
  #32
Well , unfortunately my exhaust has the rusty/fused bolt syndrome so i`m gonna need torches to get it off , but I don`t have any & it`s a PITA to do this under jack stands anyway so I`m going to have to wait till I can do it after work with the use of a hoist sometime this week .
Old May 30, 2010 | 09:02 PM
  #33
BlackNiteWS6's Avatar
Originally Posted by The Alchemist
I have the powerflo with long tubes and ory on my car and love it. It's very deep at idle, and you learn how to drive through the rasp between 2200-2600 without getting it depending on throttle position. I've had probably 7-10 different exhaust setups on my car over the past 10 years, and this is my favorite by far.
Hey Bri it's Dennis...i like the PowerFlo CB too. But do you think it would be
to loud if the muffler in the I pipe wasn't there? When i order this exhaust i thought about just runnin the 2 rear mufflers only. I used to run FLP w/o cats
and ran with Borla open..lol. So loud i'm used too. Thanks buddy.
den
Old Jun 3, 2010 | 09:38 PM
  #34
coxta's Avatar
I am also thinking about getting this catback. My current exhuast is too loud and raspy since i did HCI. Eventually I want to replace all my exhuast with stainless steel exhaust anyway I just wonder how it sounds not only at idle and reving but under WOT also. POST VIDS!
Also, what size comes out of the rear powerflo mufflers? 2.5" or 3" I would like to keep my corsa clone tips.
Old Jun 4, 2010 | 09:05 AM
  #35
Badguy7's Avatar
Any exhaust shop can modify the mufflers outlets or your corsa clone tips to fit.
Old Jun 4, 2010 | 09:54 AM
  #36
kdick91's Avatar
IMHO, I would never change the exhaust setup I have. I had an LM1, but when I switched to Pacesetter LTs and an ORY, I went with the 'Borlamouth' setup and had a show weld in a Borla XR-1 muffler in place of the resonator (not exact fit, so don't expect it to bolt up). And it is just NASTY. I don't want to sound like I'm just blowing my own horn, but I did alot of research before I spent money and still continue to inquire about opinions. So let me be honest, it is loud. Not cutout loud, but pretty close. I won't be getting a cutout. At idle and low RPMs, it is VERY deep and tame. It does show a little rasp in that range, but screams everywhere else. Very consistent sound except for rasp. My friend has Hooker LTs, Hooker ORY, and Corsa's overpriced catback (chamered) and while his sounds pretty good, its not loud and just doesn't have the same aggressive sound as mine. Sorry to type a paragraph, but I feel for your woes. Haha. Hope that helps.
Old Jun 4, 2010 | 01:25 PM
  #37
evo462's Avatar
I have LT's/ORY/LM1 + Borla and I don't think it's that loud. It's about the same volume level when I still had stock manifolds/y pipe + LM1, but has a much meaner note to it now. I think it sounds great.
LM1+ORY+LT's was obnoxious though...couldn't stand it.
Old Jun 4, 2010 | 05:46 PM
  #38
coxta's Avatar
I just decided to sell my corsa clones with my cat back since they are welded on anyhow so I will just end up buying new Corsa clones, thats why i was wondering the size, then I can just buy the correct size to slip on or have my buddy weld them on.
Old Jun 7, 2010 | 06:16 PM
  #39
OK Guys ! I finnaly have some new pic`s for ya`s ( Still trying to get the video to work ) .
Old Jun 7, 2010 | 06:39 PM
  #40
OK now I have a video !
It on a cold start & I reved it up alittle past 4000 RPM .
http://www.youtube.com/watch?v=qK82LaeuvCc
