vacuum leak? Please help!! MONEY RACE FRIDAY!!!
To the OP, sorry to hear about this. Your car is a freaken monster and i hope you can get it all figured out.
Yea its a manual master from burkheart chassis. I was thinking today and this problem started happening around the time i installed my lingenfelter 2step, and timing tuner. If the box was messed up and kept pulling timing would this cause a similar problem as to what I have? I am going to unplug it from the coil packs tommarow, and see if that changes anything. But that still doesnt make any sense as to y it is locking the converter in the 1/8th mile.
One other question I have is if the car was tuned on TR6 plugs, and I switched to a BR7EF would it not run right? Or at least not as strong as it would with the TR6 plugs? I had a buddy mention that to me just as a idea.
well, honesty (if possible) i'd take the computer out of the equation and put TCC on a switch. alot of mustang guys do this with solid results. +3-4mph.
and what it'd do is (depending on how right the idle is now) is foul pugs quicker. you're running a colder plug, and thats a "side effect." to the detonation resistance a colder plug gives. depending on how often you spray, you might wanna put a tr55 in until you're at the track. i'd even say pull a plug after some street driving. you should be pulling your plugs fairly often anyways.
What would cause there to be little to no vacuum in that area? Would that cause the idle to be high?
