ported throttle body PICS
This is my first time porting anything. let me know what you guys think? I used two different file bits on my dremel. I can take pics of what they looked like if anyone cares. I followed with 220 grit sanding drums. last I sanded by hand using 220 > 800 > 2000. Then mothers aluminum polish by hand.
my (and this is only mine) experience with the epoxy mod is that it sometimes (and i did say sometimes not always) seperates from the housing as the metal constantly heats and cools. i have repaired several t/b's where i had to remove the epoxy entirely. could it have been a bad mix, of course. bad application, of course. does it happen to every throttle body that i have seen with the mod, nope not even close. i, me, and only my opinion is that i would rather not give anything the opportunity to be inhaled into my motor if i dont have to.
now back to giving this guy props. the port job looks great, the polishing looks awesome and it appears that the epoxy is seated nice and tight. job well done in my opinion.....
http://www.installuniversity.com/ins.../tb_bypass.htm
You don't need to buy the BMR kit to do it, just go to Lowe's and find a fitting that will slide in the 2 hoses and make sure its tight and ur done. Easy power lol
Lol I posted that pic b/c I thought that looked cool. Thought it could prove the polish job!
I used number 115 and 117 in the pics. not sure if these are the same dremel brand ones I used but they looked just like that!
see above post.
Yes, its still the stock blade. I knifed the edges and polished the cross hatched grooves off of both sides.
], but I may have some credibility being an engineering student. I passed fluid dynamics last semester ( flowing intake air can be treated as a fluid) and believe the epoxy greatly reduces turbulence the cutout creates. I also believe the intake air temp. sensor ( Correct on type of sensor?) would not be affected by the mod in my case. When the intake valves open you want as much air/fuel mixture to fill the cylinders as possible in that brief amount of time the intake valve is open. The epoxy lowers the overall drag force of the intake channel which can make the air travel faster, maximizing the amount of air in the cylinder. Again this is my opinion. I really spent my time on the project working on it over a couple days.
I would say about 6-7 hours.
I could try to make one, but dont have pictures of the complete process. Would maybe need someone to take some pics of a stocker. I was a little disappointed seeing the sticky for this mod had deleted pics.
hope this helps someone!
