High idle after P&P throttle body swap
I just installed a stock LS1 P&P TB on my 2002 Z28. The install went fine but when I started it up and took it for a test drive, I noticed that it idled unusually high and after I revved it, it took longer than normal for it to "come down". It's idling around 1100+ RPM right now, normally it's around 8-900 RPM and returns to idle quickly after a rev.
I adjusted the "post" that the throttle arm rests on the throttle body housing and lowered it to where part of one thread was showing, similar to my original TB. When I rev it, it'll kind of hang around 1600 RPM for about 3 seconds, then quickly drop to 1100 RPM.
It's like the car thinks the throttle position is slightly open, and it's not idling right. There's a SES light which I haven't checked, but it came on earlier today prior for the EVAP system (PO400) so it's possible that is what its on for again.
Thoughts?
Thoughts?
Restricted User
plugging/covering the idle air hole is possibly a band-aid and not a fix. there are a couple other things that you can try prior to that. the are you sure you reinstalled the the o-ring on the iac sensor? do you know how to do a manual re-learn with the tps??
Restricted User
the way i always suggest it be done is as follows...
with the key off, unplug the tps / throttle position sensor
turn the key on / forward in the on position for 10-15 sec
turn the key off
reconnect the sensor, start her up and see how she acts
still tho, double check the o-ring for proper install and damage.
turn the key off
You're right...all I have to do is remove the air intake haha. Anyway, here it is. The TB looks straight and the seller was great to deal with, so I am certainly not trying to slight them.
![](http://i198.photobucket.com/albums/aa309/evo4620/P1000169.jpg)
![](http://i198.photobucket.com/albums/aa309/evo4620/P1000170.jpg)
turn the key off
turn the key off
I dunno. Maybe the TPS or IAC is crapped out and my fondling it during the swap finally made it go kaput. I guess I can have O'Reilly's scan it tomorrow and see if it pulls up anything suspicious.
![Embarassed](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_emb.gif)
I certainly don't feel comfortable putting a bolt through that hole so I guess I'll just take the TB off.
*edit*
I just went out and tried covering up the hole...yep...idled like normal with just the smallest amount of the hole covered up. After comparing the two, the ported TB's hole is a tiny bit bigger which I guess makes all the difference. It's too bad it won't work for me, it felt great at WOT.
I'm going to swap my stock blade back on and see what happens.
Thanks for everyone's help!
