long black sensor behind intake???
Old Jan 11, 2004 | 09:07 PM
B18B1LS1's Avatar
Default long black sensor behind intake???
Can someone tell me what the long black sensor is that sits directly behind the intake? Its the one that threads in and sticks up, it is right next to the one that sits down flush in the block. I broke the stupid thing and need to buy a new one Any idea on how much it will set me back? Thanks.
Jeffrey
Old Jan 11, 2004 | 09:35 PM
MM98's Avatar
That would be your oil pressure sensor my friend.. I broke mine as well when swapping out intakes..
Old Jan 11, 2004 | 09:39 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
I think most people break this during one intake swap or another. I was warned about it long ago and always am very careful of it now.....
Old Jan 11, 2004 | 09:44 PM
WS6FirebirdTA00's Avatar
im gonna do an intake soon can you describe it more and how i need to be careful around it. like what not to do lol
Old Jan 11, 2004 | 09:45 PM
MM98's Avatar
Yup.. Had the intake bolted up & started the car & was like WTF I have no oil pressure!!!! Well after about having a heart attack from seeing 0 psi on the gage I took the intake off & behold, found the sensor just chillin there broken.
Old Jan 11, 2004 | 10:00 PM
it was just there chillin....i like the use of words there lol
but seriously i need some tips on how to avoid this so i dont do it lol
Old Jan 11, 2004 | 10:05 PM
MM98's Avatar
Just be really careful when your installing it.. Do not force it, make sure everything is in the clear & it should go in pretty easy..
Old Jan 12, 2004 | 02:11 PM
jd13's Avatar
I did the same thing MM98. I about **** myself too lol.
How to avoid it: go about normally taking the intake off. The large vacuum hose that goes to the brake booster from the back of the intake manifold is what broke mine. The oil pressure sending unit sits in between that hose and the manifold. Lovely design. It's next to impossible to take that hose off the rear of the manifold while it's still in the car. So what you have to do is be very careful when lifting the manifold. Get your arm/hand back there and just guide that hose above the oil unit before you yank that thing out. Do the same when putting the new manifold back in, guide the hose in first and don't push the manifold back too far.
Old Jan 12, 2004 | 02:53 PM
PongoX11's Avatar
Welcome to the club, broke mine and had to drive over an hour away to the nearest dealer that had them in stock.
Old Jan 12, 2004 | 06:47 PM
B18B1LS1's Avatar
Cool, thanks for the info!
Jeffrey
Old Jan 12, 2004 | 07:49 PM
Jorday's Avatar
I broke mine, too. It was a long time ago on my old car.
Old Jan 12, 2004 | 08:51 PM
BadAndy's Avatar
And make sure you lift the manifold straight up, not just from the front. As you bring it forward a little it will get away from the sensor and you don't have to worry about it as much. I think that little bastard costs about $60 bucks.
Old Jan 12, 2004 | 09:16 PM
Assassin's Avatar
yep broke mine the first time too, thats an extra 20 dollar part to put on the list, next time take it out first, you can get the right size socket from your parts store!
Old Jan 13, 2004 | 11:30 PM
ssdungeon's Avatar
I broke one also for the record. I wish I were warned...LOL.
I think it was $48.00 or less to replace.
