COIL upgrade
Old May 19, 2010 | 11:17 AM
CajunZ's Avatar
Default COIL upgrade
Are MSD blaster coils an upgrade worth the power for the money?
Old May 19, 2010 | 11:25 AM
getusum's Avatar
Get some truck coils,,,,,,
Old May 19, 2010 | 11:38 AM
99'CajunFirehawk157's Avatar
Its like coke or pepsi, some say yes, others say no.
Howdy neighbor
Old May 19, 2010 | 11:40 AM
7camaro7's Avatar
I have some truck coils for sale with the heat sink on them. pm me if you want them. They're not prone to failure like the msd coils are known for.
Old May 19, 2010 | 11:42 AM
blackfbird98's Avatar
which truck coils
Old May 19, 2010 | 11:46 AM
ShortChevy's Avatar
MSD coils are pretty much junk and don't last. If your not having any issues with spark blow out or your not on a bottle you won't see any gains really. Leave the stockers on there, they are plenty powerful for 97% of people and are a good coil. Spend the money elsewhere.
CajunZ's Avatar
6.0 coils i am guessn?
Old May 19, 2010 | 11:48 AM
If you search "truck coils" you will find a ton of data on this...
CajunZ's Avatar
Wassup 99cajunfirehawk157 !! will check that out
Old May 19, 2010 | 11:49 AM
https://ls1tech.com/forums/generatio...p-18-6-tq.html
7camaro7's Avatar
yes, truck coils with the number d585 and I believe they come on 6.0L and larger. They have heat sinks on them. They make startup easier and most people fine hp/tq gains.
Old May 19, 2010 | 12:13 PM
SweetS10V8's Avatar
Truck coils also have a different dwell setting, and you have to adjust your tune accordingly. I still dont think the coils make any difference.
Old May 19, 2010 | 12:39 PM
robsls1's Avatar
Honestly I didnt see no improvement going to the MSD coils. The only improvement I seen was replacing the dead, low spark, cracked casing MSD coils back to stock.
Old May 19, 2010 | 05:57 PM
7camaro7's Avatar
just to put things into perspective, w/ my truck coils I dynoed 350rwhp/362rwtq SAE! I have seen several cam only cars that put out lower numbers than mine. I have a bone stock engine. Just boltons.
Old May 19, 2010 | 08:10 PM
SweetS10V8's Avatar
How does that put anything into perspective. It takes all of 15 seconds to make any dyno say your car makes 400hp.
Old May 19, 2010 | 08:20 PM
djfury05's Avatar
uhh I dynoed 349rwhp and 367 tq with headers/tune..... that doesn't put anything into any perspective..
If your car is a high mileage car OP then you may see a slight increase due to a renewed stronger spark coming from the 6.0 coils. Look at the thread where the guy gained some 18hp or some ****, the car had high mileage... some report no gain. Any your going to have to dish out more money to have ur tuner put the dwell time tables in and all that jazz.. it ain't worth it to me personally
Old May 20, 2010 | 09:16 PM
7camaro7's Avatar
My numbers are SAE and not STD.
SAE, which produces the same numbers no matter what time of year or the temp for a given set of mods levels the playing field. apples to apples
STD is inaccurate because on a cold day it looks like you've got way more power than you had than in say the summer of the same year. apples to oranges to potatoes. You can get a million different dyno numbers as long as the environment keeps changing. SAE corrects for all that and makes the numbers comparable. Thats how it puts it into perspective.
Old May 20, 2010 | 09:22 PM
xpndbl3's Avatar
lol, no two dyno's read the same regardless of correcting for weather conditions.
Old May 20, 2010 | 09:29 PM
7camaro7's Avatar
Well its a good thing that I used the same dyno then isn't it?
Old May 20, 2010 | 09:34 PM
blkm6formula's Avatar
yes the same dyno helps, however look and 99% of dyno charts, same car, same, everything, 30 seconds later and will experience a diff. number. its not uncommon to see a 10hp diff. in your 3 pulls on a dyno, SAE or STD
