New vs Old LS6 Valley Cover ?
Old 05-06-2011, 11:37 AM
  #61
patSS/00's Avatar
Both the old and new style ls6 valley covers have an "air-oil separator" (that's what the box thing is). The difference is the new style is sealed except for tiny holes in the bottom cover, which are the "PCV valve" (not really a valve, just a restriction). I found some mention of this restriction maybe being able to cause crankcase pressure buildup in some conditions. I put the old style in mine. If I want a restriction type valve instead of the regular kind, I can change it easily.
Old 05-07-2011, 12:43 PM
  #62
02SOMLS1WS6's Avatar
I have a couple of questions, as I want to do this mod next weekend.
1) Someone told me to get a LS2 valley cover is this the same part number that you are talking about when you say 04+ LS6 cover?
2) I will be using a procharger on my car and still want to do the catch can set up for the added insurance, this valley cover will still work great with the catch can set up correct?
Old 05-07-2011, 12:54 PM
  #63
Also I need to go look under the hood but everyone says how the layout is all cleaned up. Does anyone have any pictures on what lines are no long needed when switching to the LS6 style?
Also is this even really needed if a catch can system is installed? The reason I am still thinking about it is with the LS6 style the valley cover hose hook up is located nicely in the front of the engine so easy to hook up the catch can system cleanly.
Old 05-07-2011, 01:44 PM
  #64
sjsingle1's Avatar
you remove that big ol useless stock PCV hose.......thats a pretty good clean up right there
Old 05-07-2011, 01:56 PM
  #65
Ya I see that now, found a good write up on LS1howto.com. I guess I will be doing this mod, I saw that I had the "bullseyes" on my block so that sucks looks like I will have to clearance the block for the valley cover to fit. I was hoping mine would be an LS6 block since its an 02 and probably towards the end of the LS1 production run.
Old 05-07-2011, 05:25 PM
  #66
sjsingle1's Avatar
dont forget some new knock sensors(2) and wiring harness.......dont want to get in there and find out you need em and dont have em
Old 06-14-2011, 11:09 AM
  #67
Bryceslu's Avatar
For the people who have already done the newer ls6 valley swap.
It appears it would be impossible to use the ls1 coolant lines as the little nubs on the ls6 valley would be in the way right??
Especially if you go with a ls6 intake and try to knock off the ribs to use the ls1 lines.
Old 06-14-2011, 11:17 AM
  #68
oakley6575's Avatar
Use block offs in the rear and a crossover tube up front.
Old 06-14-2011, 05:02 PM
  #69
HoLLo's Avatar
Also, LS6 coolant lines are like $65, if you just wanted to convert to those. Anything required to make the 04+ LS6 Valley Cover to fit is worth it.
Old 06-15-2011, 12:20 PM
  #70
Floorman279's Avatar
So if i do this on my98 ls1 with ls1 intake, i will need the coolant crossover?
Old 06-15-2011, 01:01 PM
  #71
patSS/00's Avatar
No, with the ls1 intake the old coolant pipes will still fit, with just a little bending at the front to get around the outlet from the valley cover.
Old 01-10-2012, 07:51 PM
  #72
Revson's Avatar
I know this thread is a little old, but I am getting ready to do this and was leery of grinding in the block. I talked to a friend of mine who builds off-shore power boat motors for a living and he told me to take as big a continuous piece of tin foil as I could fit in there and put that in first, tape it together if you have to, but make it as big as you can. Then lay the rags on top of that and make them slightly damp as the grinding dust is more likely to stick to the damp rags when you pick them up.
Also I am going to rig up my shop vac, or have someone hold it as close to the grinding wheel as possible while I am doing the cutting.
Thought this might help someone it the future.
Old 01-12-2012, 12:45 AM
  #73
HoLLo's Avatar
It's actually very easy to cut the block. I was able to fit a fullsize hacksaw in there to make a vertical cut, then took some vise grips, locked onto that notch and broke it off. Had some rags stuffed over the cam and everything else under the valley cover. Then used an oil soaked rag and a vacuum to get rid of the shavings which took the longest time of the whole mod.. Using a hacksaw will minimize shavings. This was almost 2 years ago and was well worth te effort. I keep that little chunk I broke off in my car with me
Old 01-12-2012, 07:50 AM
  #74
slt200mph's Avatar
No need to make this into some kind of a big deal to worry about. Just do a good job of covering up and have at it. Did mine back in 2004 and have put over 200,000 miles on the car since then. Just use a little common sense when you do it and it will work out just fine. Did the LS6 valley cover and intake at the same time.
Old 01-12-2012, 11:40 AM
  #75
Rare96LT1Formula's Avatar
I'm gettin ready to do an LS6 Mainfold/LS6 valley cover swap on my stock 2000 LS1. So far I have the manifold and new intake/tb gaskets. If I were to order the LS6 VC from gmpartsdirect, does it come with everything needed to do the swap? Am I missing anything???
Edit : I may eventually add a catch can to this setup.
Old 01-12-2012, 12:47 PM
  #76
Revson's Avatar
It comes from GMpartsdirect with the gaskets and bolts. There are a couple of other things you may need. There is a parts list on here:http://www.ls1howto.com/index.php?article=18
The part number for the VC on this list is for the old style one, if you want the newer one with the internal PCV its: 12577927
Old 01-12-2012, 12:50 PM
  #77
Revson's Avatar
Here is a catch can write up with the new PCV: http://forums.corvetteforum.com/c5-g...up-no-way.html
Old 01-12-2012, 01:13 PM
  #78
docwyte's Avatar
I did this on my LS1 converted Porsche 944 a few weeks ago. While thinking about cutting on the block is daunting, actually doing it was very easy. I covered everything up very well with rags and sealed it with duct tape first. Then I measured down 3/4" of an inch and marked the horizontal cut line using a sharpie. Plugged in my air powered cut off wheel and went to town! I then cut down from the top with the cut off wheel, broke off the piece and cleaned it up with a carbide bur.
I did have to bend the LS1 coolant tubes a little on the front to get around the LS6 brass barb, but that was easy to do with a set of channel locks.
I also have the Elite Engineering catch can, hose goes from the LS6 valley cover to the catch can that's mounted on the front of the passenger's side head, then out of the catch can to the PCV valve that's then plugged into the intake manifold.
Old 01-12-2012, 01:42 PM
  #79
Thanks guys!
Old 01-17-2013, 03:24 AM
  #80
blak_ls1's Avatar
I just ordered a ls6 valley cover.. since I am swapping the ls1 intake for an ls6 i might as well do this mod... i already knocked off the ribs on the ls6 intake. my question is can i run a ls6 valley cover and ls6 intake with the ls1 coolant lines.. will they still clear ?
Quick Reply: New vs Old LS6 Valley Cover ?
