New vs Old LS6 Valley Cover ?
"What they did was to engineer valley mounted oil separators which uses internal baffling to force the crankcase vapors in a circuitous (think roundabout) flow. This in turn causes the oil to separate and drain back into the engine."
And also there is a fixed orifice set in the valley cover, therefore no need for external PCV valve. The older style does not have the orifice and therefore requires an external PCV valve.
Scoggin-Dickey carries both parts.
Part no for 04 style : 12577927 $74.69
http://sdparts.com/details/gm-factor...parts/12577927
Hose: 12594779 $3.29
http://sdparts.com/details/gm-factor...parts/12594779
This is from LS1howto
and then what it looks like without it. Note to the left of the throttle body the U-Shaped hose pulling vacuum from the valley cover to the intake. No more PCV hose running around the motor. Much cleaner..
I was also replacing a bad knock sensor while I was in there
That's the older style LS6 cover though. Does anyone have pics of the new style LS6 cover?
