New vs Old LS6 Valley Cover ?
#81
It's not mine! woo hoo!
Here are the three parts you'll need:
Parts list: valve cover plug (12568011), valley cover to intake hose (12594779) and valley cover with built in PCV - aka: 2004 LS6 PCV (12577927).
I would also *highly* suggest new manifold gaskets. I used Felpro from Advanced as I was in a pinch (already had it apart), but had I known ahead of time, I would have just ordered the GM/ACD gaskets - 12533587
Here's what my cut looks like:
All back together:
All back together:
#83
I just ordered a ls6 valley cover.. since I am swapping the ls1 intake for an ls6 i might as well do this mod... i already knocked off the ribs on the ls6 intake. my question is can i run a ls6 valley cover and ls6 intake with the ls1 coolant lines.. will they still clear ?
#84
I borrowed this picture from another forum. This should give an idea what they are talking about. You can see they both have ribs but the LS6 intake on the left does not have the recesses like the LS1 intake on the right causing the need to remove the fins when using the older coolant lines.
#91
So the LS1 coolant lines will sit up a bit because of the raised nubs on the LS6 valley cover, I think that is where you are saying the issue is. Is that only an issue for the lines to fit under the intake or does it not allow them to bolt down to the heads? Or since my intake underside has already been smoothed down, will it no longer be an issue and the lines can just rest up on the LS6 VC nubs???
