Blowing smoke on down shift
Old May 24, 2010 | 06:54 AM
NitrOmm's Avatar
Default Blowing smoke on down shift
I seem to be burning oil on a long hard down shift. I suspect an oil build up in the intake. I am upgrading to a fast 102mm/96 combo in a few weeks. What souls I look for and what can I do to prevent. ( catch can for sure)
thanks
Patrick
Old May 24, 2010 | 07:14 PM
conan's Avatar
Catch can should catch most of the oil. How many miles are on your heads?
Old May 24, 2010 | 08:43 PM
crainholio's Avatar
Smoke during high vacuum intervals, like coasting in gear and letting the engine slow the car, usually points to valvestem seals.
Old May 25, 2010 | 12:26 PM
OUTLAWZ RACING's Avatar
valvestems....
Old May 29, 2010 | 01:12 PM
NitrOmm's Avatar
thanks guys,
The heads are new, 10K miles on them now but it has been doing this since the total build. I have also noticed that i loose a quart every 2.5K miles.
Old May 29, 2010 | 04:37 PM
cyberkill's Avatar
Better than me! I lose like 2.5qt every 3K miles.
Old May 30, 2010 | 11:39 PM
"Grabby" 2000Z28's Avatar
Default Smoke
Yes , downshift causes oil to be pulled into the cylinder through the valve stems . Smoke under acceleration is oil pulled past rings .
However , when I was useing 5-30 oil the engine would pull oil into the intake through the PCV . There is a fix on this site to change the PCV valve location . It seemed rather involved though .
I changed to 10-30 and do 1.5 quarts every 3,000.
Old May 31, 2010 | 02:34 AM
brian_rs/ss's Avatar
i had a couple valve seals push up on me, i was burning oil like i was trying to get high off the ****. now i'm back to the normal puff puff that the ls1's let out. but thats because i haven't upgraded to a ls6 style pcv yet. catch can helped though.
Old May 31, 2010 | 12:16 PM
cyberkill's Avatar
I thought catch cans only stopped oil from going back into the Intake Manifold by cooling/condensing oil vapors and having filters to catch them. So, wouldn't you still lose the same amount, but just not burn as much? .... or were you talking about it helping from blowing smoke?
Old May 31, 2010 | 05:39 PM
i know this, i was talking about after i had the valve seals fixed. a catch can can help with oil consumption through the intake. but an ls6 pcv system would be even better.
Old Jun 1, 2010 | 01:15 PM
TORCHD 02 TA's Avatar
Originally Posted by OUTLAWZ RACING
valvestems....
and OP.. you and I have ALMOST the same cam. I blow smoke to.. espically at a stop light. I have read that stock rockers are only meant to handle .550" lift... The rockers are causing a slight wear, and the oil is seeping past it out the exhaust
I too have a catch can to
