Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Air Intake and Exhaust Guides
- Camaro and Firebird: Header Reviews and How to Install Headers
Review and how-to
Poly Motor Mounts + Pacesetter Headers + TSP Y Install For Dummies *LOTSA PICS*
#161
This Sticky was invaluable for installing my Speed Engineering Long tubes and poly motor mounts.
I might have gotten lucky, but I didn't have any trouble with installing my passenger side MM bolt. I did leave the pedestal and mount loose/finger tight until everything was hard mounted. Couple light taps with rubber mallet was all i needed.
Thanks again!
Thanks again!
#162
Another thank you as this sticky helped greatly with my motor mount and LT install this weekend. I ended up doing one side at a time for the motor mounts and had to loosen the pedestal bolts for the driver side. Then for the passenger side I used your scissor jack method and it worked perfectly.
Took about 12hrs in total but was way easier because of this thread. Thanks again!
#163
I loosened all the pedestal bolts on both sides. I jacked up the motor ever so slightly. I unbolted one of the motor mounts and its pedestal, and removed the whole assembly. I did passenger side first, but I don't think the order matters. Swap in the poly, reassemble it and reinstall. I kept the pedestal bolts loose so I could repeat the process on the driver's side.
None of my issues were with bolt alignment. 18mm bolt installed on the workbench so that was a breeze. Pedestal bolts lined up easy. Motor mount bolts lined up with very minimal effort. My issues were a gummed up thread and a washer too big to pass the poly mount.
Thanks,
Scott
