A.i.r.
Old Jan 12, 2004 | 06:26 PM
z28hokie's Avatar
Default A.i.r.
Does the AIR system only function when the engine is cold? And when does it disable itself?
Old Jan 12, 2004 | 06:31 PM
jrp's Avatar
jrp
SN95 Director
its only function is to help pre-heat the cats during warm up to keep emissons down.
Old Jan 12, 2004 | 06:37 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Exactly. It will cut on at startup (cold or semi-warm) at pre-programmed temps and run until the motor reaches a certain coolant temp. I forget what the cut off temp is though...
Old Jan 12, 2004 | 06:38 PM
emarkay's Avatar
Correct, and it also plays apart in getting the HO2S up to temp, too! - Yes, you can hear it working, and as car goes into closed loop it shuts off.
Def not like old 1970's cars that had it basically on all the time... Back then you could gain maybe 1 or 2 hp by removing the pump, and therefore, what do you think is one of the rarest part for a 1970's musclecar restoration??? The AIR pump!
Old Jan 12, 2004 | 06:46 PM
z28hokie's Avatar
Ok, thanks. I figured as much. I can use LS1 Edit to delete the codes I'm assuming.
Old Jan 12, 2004 | 06:47 PM
RPM WS6's Avatar
Yep.
