The fix for my endless alternator failure's
Wondering why not get a new unit from alternatorman with the 140 amp upgrade?
Fits in the stock location, uses all the factory bolts, should last as long as an oem new unit, and has the 140amps to eliminate any dimming issues.
Thanks
Tony
So after some sleuthing, I found a number 20989650 that kept being referred to in all of the 321-2128 number sale pages. When I look at the 20989650 page, it refers to 19244751 and 321-2128, which appear to be reman numbers for the KG3 coded alternators (145a). That 20989650 P/N is for a 2010 or so diesel 400ci GM diesel motor, but every GM page I visited cross-referenced 321-2128.
Here's the kicker. Where the 321-2128 number is listed for no less than $250 as a reman KG3 145a part, the 20989650 appears to be new for $95! KG3, 145a, everything you'd want!
So I said screw it and bought the 20989650. I'll report back, watch it show up in some random cube shape or something, lol...
I did a 145 remay swap back in 2012 or 2011. Now my buddy's Z28 needs to swap his. Since I told him to upgrade while it has died.
Merry Christmas
Thanks
Tony
Glad to see you guys doing well with this, for those of you that have so many questions, all the answers are in the FIRST post of this entire thread.
Only thing that hasn't been addressed I believe is whether to put the alt in with the bracket attached. NO! The bracket needs to be separate. Slide the alternator between the sway bar and fans. It'll go, just push. Don't loosen fans or anything.
Is it not powerful enough?
I am currently building a new engine for a project.
I have yet to decide if I am going to get a Camaro 105A alternator or a 145A truck alternator.
Do you suggest me to go straight for a 145a truck alternator instead of a 105A one?
I'm bumping this thread as it's relevant to my situation. I was driving to Augusta GA yesterday to see my girlfriend (I live in Columbia SC) and about the time I got to the GA border I had a "Check Gauges" light come on. I looked and the voltage gauge was very low and just kept getting lower. I was just cruising down the interstate in 6th when it happened so it was the result of some WOT pull or anything. After a couple of minutes all my gauges other than the "Oil Pressure" gauge died, (tach, speedometer, odometer, etc) the headlights when out, but some of the lights like the seat belt, check engine, and ABS lights would flicker on and off and make a beeping noise. Oddly enough the radio still worked as did the power locks and windows even though they were week. I was able to limp it the rest of the way to my girlfriends house but that was a PITA as the motor would surge up and down at idle and while it would rev fine in neutral or with the clutch compress it would choking if you tried to rev it much with a load on the wheels.
Here's a video right after I got to my girlfriend house before I turned it off.
I have to get it back to SC to really look at it, but I'm guessing it's likely the altenator went bad. Car barely has 34K on it and in terms of the motor is stock other than a Flowmaster exhaust and drop in K&N. I did put a Kenwood DVD player in it about 2 weeks ago with one of those Metro modules that lets you use the steering wheel controls with it so I have both of those grounds running the the factory harnesses ground as well as the ground for the parking brake to let it play DVD's so maybe I'm over-grounding the factory ground which killed my alt? The only other stereo mod is some CDT convertible component to replace blown door speakers.
Anyway to make this relevant to this thread I'm wanting to upgrade to the 145 volt truck alt. I want to make sure I buy the right parts for the job though.
Is this the correct alt to buy? All the review are people with late 90's and early 2000's GM trucks upgrading. It's supposed to be a AD244 housing. People upgrading to it are claiming to have to run a slightly longer belt with it though as it's a larger housing which changes the pulley location. Is this necessary on a Fbody? Do we need to do a larger power and ground cable upgrade for this alt? I think it's refurred to as a "Big 3" mod?
Also just to make sure this is the harness that we should replace correct?
http://www.ebay.com/itm/LS1-Alternator-Wiring-Connector-Pigtail-98-02-Camaro-Firebird-1-wire-/271528818582?hash=item3f3860f796
Thanks for your help,
Jesse
EDIT: BTW after I cut my car off it was dead and the switch would click, but not try to turn the motor over. After about 30/45 minute it did build up some charge where it would start to turn the motor over but not enough to start it.
you dont need to upgrade the wiring (although it would help)
Truck Alt mounts with 2 bolts (rear bracket for F-Body alt is not used)
you can either use a 4 pin 244 or 2 pin 244.. (2 pin 244 would use a new plug)
I have the 2 pin AD244 out of an 06 Silverado on mine and its been fine for almost a year since I put it in
http://www.amazon.com/gp/aw/d/B000C3...ZpL&ref=plSrch
BTW I was referring to the alternator as using volts instead of amps. Sorry for the mistake. Lol
And on any car you change the crank pulley size you would need to change the alternator pulley to compensate for the change if you wanted the alternator to spin at the same speed it previously did.
The fbody alternator isn't even a store stocked item anymore. It was posted that they are rebuilding these with the wrong size components which explains why they can fail nearly right out of the box
Cheers and thanks for the advice, I'm about to replace my own alternator. After 18 years she is bouncing around on the volt meter between 13.5 and 14.2 wildly sweeping across the dial, still passing the test but it's just a matter of time.
If you want to know if they are the same get the part number on autozone's website for the duramax and for the above listed truck and compare them.
i went to autozone and got an alternator for an 02 2500HD 6.0 145amp
i got the "Duralast GOLD" that is brand new since it was only $20 more than a reman so i figured why not.
