is the SLP MAF any good?
car is a 99 WS6 A4 w/ stock MAF and throttle body and 75mm LGM 75mm air lid.
also what type of Home depot (fenco bellows) would be required to make it work?
I can't exactly remeber think this SLP MAF had poor feedback from it's users.
Thanks
And it comes with a sleeve that fits over the stock lid.
Don't remember the pipe size though but a search for smooths bellows should turn something up here.
I bought the SLP a few months ago. My dad bought a truck MAF for his ls3 build and when it got in i was looking at it, took mine off, and compared them. I was pissed. I payed around $250 for the slp and he paid $40 for his shipped to out door
Make sure you get the ecu calibrated for either one though. its worthless unless you do that
Also you MUST get a tune for the different MAF sensor. The tune that is in your car is calibrated to translate the frequency of that MAF sensor into airflow. If you change the meter that tells the frequency then you obviously arent going to get the same airflow! They are alot different than the aluminum style MAF sensors!
Also the SLP 85mm is slightly different. There is a different resistor in the SLP version to make it read similar to the aluminum style MAF so it won't throw the car off as much running a stock tune. Those particular MAF sensors don't have the frequency maxxing out trouble the OEM Truck MAF sensors do.
I ran a 85mm truck MAF on both my Camaro and my TA and maxxed it out on both haha. My Camaro maxxes the PCM out at 512 g/sec and the 12,000hz frequency limit. My TA maxxed the frequency limit out since it's 98 and read's 11,250hz above 6000prm. I have one for sale with a IAT/MAF adapter harness.
version of a $40 eBay truck MAF. It's the only thing
soldered to the backside of the bridge post-factory,
you can't miss it.
I had no particular problems with the '01-'02 version,
as-stock. No particular upside either.
The issue is that the resistor "bends" the calibration
to what SLP says is stock, but they have no clue of, or
don't care to pass along, a good table. "Good enough"
seems to mean different things depending on whether
you're selling or buying / tuning.
With a little care the butt of the 85mm MAF will fit in
the stock bellows. I am set up that way.
think I'll keep the stock MAS it's still working fine.
was concidering a used SLP for an upgrade and to have a spare.
thanks Guy's for the feedback.
