Best spark plugs for the ls1
-Steve
I'm sure any Bosch platinum will outlast any NGK copper so in that regard it's not crap at all. But I want to go fast first and extend my plug changing intervals second so TR55s it is.
This is a technical forum. If you don't like the question. MOVE ON! Personal attacks will not be tolerated!
. You started the personal attacks to which I should not have responded to in kind. You seem to be the only one that is angry with me for questioning so you should MOVE ON. Being an engineer, I wanted more insight into this testing and inquired about these facts. Otherwise, it is personal opinions with some that are formed through experience with a product. I have never used TR55's. Does that mean I can accurately comment on them? Just cause you use them have you ever REALLY compared them to others besides putting them in and driving around? Usually plugs are replaced because they are worn out so of course the new will feel better and your mind (or seat of the pants) will tell you that you gained power. You can respond to this if you like, but for me I've had enough.
Sawedoff and Edmonton, good input. Did not know Bosch was so expensive though. I've never used them either. The pricing and claims that you say they state reminds me of the old Split Fires. What a crock those were.
These (+4's) are a good service replacement plug. They do work much better than the OEM units. If I were using nitrous, or under racing situations I would use another plug from their line, or a different brand. I would get a plug that I could adjust the gap with, and pick and choose a heat range with. For a long life, quality service replacement part, the Bosch line is good. This style of plug is not designed for boost applications. From the way the plug is designed it would be a "glow plug", which is not what you'd need in that application. Whether or not the extra electrodes do anything is up in the air. I just thought I'd give em' a try, and I like them.
