Bauer tb
Old Jan 15, 2004 | 02:56 AM
SLP LS1's Avatar
Default Bauer tb
I don't know if any of you guys have the bauer throttle body, but their website says it has an adjustible throttle stop. Not sure I should be messing with something like that. I'm kind of worried about that!!! I really don't want to **** any thing up. I might then just buy the MTI tb. What do you guys think?
Old Jan 15, 2004 | 03:03 AM
Blue2002SS's Avatar
I just sent mine to Bauer, I did several searches and found lots and lots of positive responces to this mod.
Old Jan 15, 2004 | 07:38 AM
Old SStroker's Avatar
Bret adds the adjustable wide open throttle set screw stop so that the blade can be set as close to 90 degrees for most flow without setting a code. In most cases his setting is very close to the max, but you can adjust it if you wish (and know what you are doing. ) It's better than grinding on the full throttle stop, going too far (setting a code), and then having to put metal back on.
My $.02
Old Jan 15, 2004 | 08:17 AM
pewter99SS's Avatar
I'm very pleased with my bauer TB. Great mod for the money. Where it was set when I got it looked good enough to me, so I didn't mess with the throttle stop.
Old Jan 15, 2004 | 08:20 AM
HOTROD98Z's Avatar
When i got my Bauer TB i just cleaned it up and bolted it on. The throttle blade was already set to open at 90 degrees so their was no need to mess around with it. Bret has good service and does a very nice job on the units.
Old Jan 15, 2004 | 09:35 AM
Classic's Avatar
I've run my Bauer for about a year now with 0 problems. Bret does a really nice job with these and the adjustable throttle stop is great. I would much rather have a little screw to adjust the throttle stop than start grinding on the casting.
Old Jan 15, 2004 | 10:35 AM
Midnight F-117A's Avatar
I have an Bauer polished and red powercoated throttlebody. It's an quailty work and the throttle stop I set to was not to exceed 4.8V otherwise an SES light will be set.
4.8V is the maximum the PCM reads for 100% throttle opening.
Old Jan 15, 2004 | 11:54 AM
SLP LS1's Avatar
Thanks a lot guys, I really appreciate all the info on the Bauer tb! Have you guys ever checked out the tpi throttle body?
Old Jan 15, 2004 | 07:14 PM
10secondZ's Avatar
What is the voltage supposed to be when the TB is closed .60v?
Old Jan 16, 2004 | 08:42 AM
Richard@WCCH's Avatar
Default Richard
According to GM it's supposed to be .5v.
Bret's work is top notch and his service is very professional.
Richard
Last edited by Richard@WCCH; Jan 16, 2004 at 08:45 AM. Reason: Additional comments
Old Jan 16, 2004 | 12:19 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Mine is working great...
https://ls1tech.com/psjpics/griffinpics/griff10.jpg
Old Jan 16, 2004 | 12:22 PM
Hardtop's Avatar
I have a Bauer TB and its very nice piece.
Bruce
Old Jan 16, 2004 | 03:54 PM
FatZ28's Avatar
Sorry to get off the subject, but what did you guys pick up in et with one of those.
Old Jan 16, 2004 | 04:19 PM
Damian's Avatar
LSX Mechanic
Not sure about ET, but mine made 11 rwhp on a BONE stock 99 T/A (girlfriends car)....
Old Feb 11, 2004 | 02:13 AM
Mean Machine's Avatar
i put mine on today, very noticable increase in power. i'm very satisfied with the bauer piece.
Old Feb 11, 2004 | 07:44 AM
Pesticide's Avatar
Bauer puts out a great product with some of the best customer service I have experienced in the aftermarket parts industry. Deal with Bret in total confidence.
Old Feb 15, 2004 | 06:40 PM
99sweetZ28's Avatar
I have had my Bauer TB for over a year and have had no problems with it. I sent my old TB to Bret and got the ported/powdercoated TB back in less than a week. Bret's work is excellent and he is very professional!
Old Feb 16, 2004 | 01:01 AM
SStrokerAce's Avatar
Right now we are a bit busy, I have some TB's in and a few LT1 race motors going out.
Good thing is it's the slow season and peoples cars are down so guys don't have to run their cars.
Also I have some FAST LSX intakes in, the 78mm are called for but I have a few 90mm ones that I will let go for $825.
Bret
