DMH cutout for borla?
As far as the wiring the cut sits on the passenger side of the car. There is a rubber body plug that is in teh spare tire well. Cut a tiny slit and feed the wire in there. Then I ran the cable along the passenger side of the car. Up threw the passenger kick panel, across the underneath of the glove box to the ashtray. Power is recieved off the cig light adn grounded the ground wire near the SIR coil.
Hope that helps ya out.
That is awesome that he is willing to warranty stuff outside of the period, that is not the first time I heard that he did that either.
I did not even think about the drain plug in the spare tire area, that will be perfect. But I had heard some ppl say their battery drained after a few days when they tapped into the cig power. I figure I can just tap into the same wire as my v1 since it is only like a foot away from where the cig lighter is.
Thanks for all the opinions and help guys.
For those who have been having trouble getting ahold of him, I called the number listed on the website and would be able to reach him most of the time. It sounds like he has some personal business that he has been trying to take care of, so he has been alittle slow at responding to emails.
Anyways it seems to be a quality piece and install was straight forward, thanks for the tips guys....its kind of amazing how much quieter the car sounds now with it closed since I had been running the open plate for so long!
DMH is .375 in. diameter, 4 yr. warranty
QTP is .5 in. diameter, 90 day warranty
So you pay more for the former, perhaps it's worth it? One thing is for sure, DMH does not run a spell checker on their website -- typos like that could indicate missed quality...
How is DMH with their 4 yr. warranty response??
http://www.ws6project.com/user_stor/...cturers_id=244
Pick up the phone and call them. Email them -- see what they are like -- BEFORE YOU BUY!
That was easy.
As for a rattle, well that should be a warranty fix, if it is reality with their current revision of shipping product.
http://quicktimeperformance.com/FAQ/...TEC66_OVAL.pdf
Last edited by Patrick G; Jul 29, 2010 at 09:53 PM. Reason: Non-sponsor link removed
Thanks for the link, but I already knew I was not going to tap a constant 12v source. I have my V1 hardwired, so I just tapped into the same line as that and hid my switch in the ash tray.
http://www.streetfire.net/video/adva...-cu_694817.htm
