Those that have removed AIR, did you remove the big pump?
Old 01-15-2004 | 05:31 PM
Dragaholic's Avatar
9 Second Club NA
Default Those that have removed AIR, did you remove the big pump?
Not sure what it is, but I figured it was some kind of pump. Its where all the hoses connected to. Its located under the front support on the drivers side behind the headlight. I figured since I removed the AIR tubes that go to the headers, I might as well pull all the hoses that run off of it. The last ones that I had was the one that ran along the drivers side panel/top of wheel well and the one that connected to the lid. Anyhow, I was wondering would I be ok to remove it. I believe I had it removed from my PCM, so I dont think it should throw any codes. I dont think I will ever put the AIR back on, so I removed that big canister thing. Plus, less weight! Am I cool without it? Thanks.
Old 01-15-2004 | 05:40 PM
Stalker WS6's Avatar
I removed mine also. No problems as of yet.
Old 01-15-2004 | 06:54 PM
Turo's Avatar
yea you can take it off. i believe it has a vacuum line on top of it (if im not mistaken), dont forget to plug it
Old 01-15-2004 | 07:42 PM
Dragaholic's Avatar
9 Second Club NA
Plug what? I took out everything. The tubes that come off the headers or manifolds if you have them, the rubber tubes coming off them, the little pump or whatever its called that some of the hoses connect to with the little one on top, the one that runs on the passenger side fender well, the one that plugs into the air lid, and then that big pump like thing below the front support behind the headlight. I took it all out and I just want to be certain that I will be ok without it. AIR is removed out of my PCM and I have blockoff plates on the bungs off the headers. So if Im not mistaken, Im good to go unless Im running a risk of taking that pump out.
Old 01-15-2004 | 07:45 PM
jrp's Avatar
jrp
SN95 Director
i removed everything, pump and hoes.
Old 01-15-2004 | 07:53 PM
Country Boy's Avatar
Senior Member
Dont forget to remove the fuse for it either or youll have a live plug dangling around
Old 01-15-2004 | 08:02 PM
Dragaholic's Avatar
9 Second Club NA
Oh yeah...I forgot to mention that I ty-rapped it to another wire loom and put electrical tape on the plug so that it wouldnt get any water in it. Is that good enough?
Old 01-16-2004 | 12:24 AM
Cheatin' Chad's Avatar
The only reason I removed the AIR system was to get rid of the pump. It weighs 10+ lbs I believe. I'll weigh it tomorrow it's still sitting in my garage. The nose on an F-Body is heavy in my opinion and anything that can be done to lighten it is good.
Old 01-16-2004 | 12:35 AM
Dragaholic's Avatar
9 Second Club NA
Wow...I never thought about how much weight I took off! I probably have a good 11 to 12 lbs. that I removed. If you add up the pump, all the rubber, and the tubes, it adds up. Awesome!
Old 01-16-2004 | 12:51 AM
MM98's Avatar
Removed mine as well.
Old 01-16-2004 | 12:56 AM
Bad Blu Formula's Avatar
The AIR pump is only there to help the exhaust flow through the cats, so if you don't have cats, then you don't need the pump I never thought about removing the fuse that controls the pump. Might be a good idea so I don't have an electrical fire from the end of the wire getting wet or something.
Old 01-16-2004 | 01:16 AM
Classic's Avatar
Same as everyone else - removed it because I didn't have cats, wanted the weight savings, and it cleans up the engine bay a bit. Thats if you remove all hoses and pump (although you can't see the pump).
Old 01-16-2004 | 01:43 AM
PongoX11's Avatar
Removed everything... Funny, my buddy was down there removing the pump pulled it out and told me my car had just given birth, and asked me to cut the umbilical cord LOL
Old 01-16-2004 | 01:57 AM
onyxxtreme's Avatar
lol @ pongo
i removed all that crap too. Sure was a pain in the *** unbolting the airpump without safety glasses. I ran to the sink at least twice, from sand in my eyes
Old 01-16-2004 | 02:46 AM
pewter99SS's Avatar
I'll have to do this. I didn't even think about it when I did my header install.
Old 01-16-2004 | 03:15 AM
Vendetta's Avatar
Originally Posted by onyxxtreme
lol @ pongo
You'd have thought you woulda learned the first time... lol
Old 01-16-2004 | 03:26 AM
2000WhiteTA's Avatar
What has everyone done with the plastic connector under the cal on the drivers side. There is I think 3 or 4 tubes connecting to it and a really small tube going to the top of it. Do yall block them off or what.
Old 01-16-2004 | 12:25 PM
Dragaholic's Avatar
9 Second Club NA
I removed that as well.
Old 01-16-2004 | 12:28 PM
2001CamaroGuy's Avatar
yep....I pulled the pump and wiped the code with LS1Edit (I was getting the code almost from the day I got the car/before I removed the pump )
Old 01-16-2004 | 01:32 PM
black_z's Avatar
I just finished removing my pump and have a coupe questions. Did you guys remove the little canister looking thing too? its about 4" high and 2" wide. It has some lines running to it.
