Getting Headers, What Else do I Need?
Old Jan 16, 2004 | 01:56 PM
Ferocity02's Avatar
Question Getting Headers, What Else do I Need?
I'm planning on buying a set of MAC headers from a board member that has an ORY. I plan on welding in cats for the california emmision *****. Here's what I got so far:
-GM Steel Gaskets (2)
-O2 Sensor Bungs (2)
-O2 Extensions (?)
I need to know what length O2 extensions to buy also, and how many of each. Thanks!
Old Jan 16, 2004 | 03:34 PM
foff667's Avatar
LS1TECH Sponsor
do a search.....JK its probably been anwsered before but get either 18 or 24" extensions depending on whats available through the company you choose i thought the headers would already come with bungs?? you could also use a hole saw and take your stockers out and weld them onto the macs if you needed them...i reused my stock gaskets ummm youll need a large jack and truck stands or at a minimum ramps...possibly a sawsaw if you had your exhaust welded together previously...some wd40...some bandaids and i like the neosporine with pain reliever...thats really about all i needed
lata
Bill
Old Jan 16, 2004 | 03:56 PM
Ferocity02's Avatar
Well, since the y-pipe is an ORY, it probably wont have the bungs that are needed behind the cats. And I need to know how many and what length extensions I need if anyone know exactly. Thanks
Old Jan 16, 2004 | 10:38 PM
foff667's Avatar
LS1TECH Sponsor
u need only two extensions...the rear o2's i just disconnected...eventually you should get the code deleted using ls1 edit or something similar...if its an ory YOU WONT HAVE CATS!!! lol so um really the rear o2's would set a code one way or the other.
lata
Bill
Old Jan 17, 2004 | 11:40 AM
Ferocity02's Avatar
"I plan on welding in cats for the california emmision *****."
Now how many extensions do I need, and how long... Thanks
