View Poll Results: Do you like the SLP 85mm MAF or not
Like
63.64%
Dislike
36.36%
Voters: 11. You may not vote on this poll
SLP 85mm MAF: curious about problems....
Old Jun 28, 2010 | 04:22 AM
taman86's Avatar
Default SLP 85mm MAF: curious about problems....
PPL are always saying that the SLP 85mm MAF is junk and i want to know why. i currently run a SLP 85mm MAF and have no issues with it, none at all, and i use the K&N FIPK II intake system so i clean and oil the filter.
Is it hard to tune or something? hell, ive had it for two years now, ran it on my bolt on 2000 with no tune with same intake system and now on my 01 with a decent sized cam, same intake system, but was originally tuned with a FTP lid, stock MAF, and ported stock tb, and have had no issues with it. i do admit that i would like to get a tune down with this intake system on it now but that is besides the point.
my question still stands, why do ppl say it is junk and dont give an explanation, i want answers, anybody's input is welcome as long as it beneficial to the thread, thanx.
Old Jun 28, 2010 | 09:18 PM
taman86's Avatar
no body has any input on this subject? alot of threads that ive read with maf's in discussion sure sounds other wise with a lot of ppl putting their two cents into it all with out giving an explanation.
Old Jun 28, 2010 | 09:22 PM
Breathing Fire's Avatar
I don't have a problem with mine. The only thing I can think of is it may be a bit harder to tune, but who cares? Your tuner or future tuner doesn't like it go somewhere else. I have only ever seen that excuse. Throws off the tune or it is hard to tune. Big deal!
Old Jun 28, 2010 | 10:27 PM
Blackhawk777's Avatar
It's more difficult to tune with, but it can be done, and the car will run fine with it. I'm running one on a stockish tune and I have zero problems.
Old Jun 29, 2010 | 02:01 AM
taman86's Avatar
ive never had to take mine to a tuner but i should now to get this intake to be tuned together with the set up instead of the stock maf and tb. but a lot of ppl dont even say that you know, just oh, its junk, dont work worth a crap, usless, etc. but im with you guys, i dont have a problem with it and even removed the screen and ive heard others say that it will screw up the air flow and such but still works fine.
Old Jun 29, 2010 | 02:04 AM
taman86's Avatar
oh, question to Breathing Fire, how do you like the typhoon on your car, i dont know if you tried the ls6 before the typhoon but i know it gives so much more then the ls1, maybe not that much more over an ls6, just curious how you like it?
Old Jun 30, 2010 | 04:56 AM
taman86's Avatar
anybody else have any input on this subject
Old Jun 30, 2010 | 05:53 AM
ULTIMATEORANGESS's Avatar
i have one also. no problems related to it im aware of.
Old Jul 1, 2010 | 03:30 PM
taman86's Avatar
so far 4 pro, 0 con. wheres all the ones that talk bad about it and why.
Old Jul 1, 2010 | 03:41 PM
gillbot's Avatar
mine's fine, my tuner adjusted for it also
Old Jul 3, 2010 | 03:09 PM
01'SSLSX's Avatar
i have an slp lid.
does the slp maf fit inside the lid like stock?
Old Jul 3, 2010 | 04:18 PM
Blownhotrodder's Avatar
Ive got one, no problems here.
Old Jul 4, 2010 | 02:57 AM
taman86's Avatar
to be honest i dont know if it does or not cuz ive only had mine on the k&n system
Old Jul 4, 2010 | 03:21 AM
PSU 98's Avatar
I've just never fully understood the mod, unless you've got an aftermarket intake setup to complement it. No matter how big the airbox/ MAF is, you're still going to have to push it all through the stock 78mm intake opening.
Old Jul 4, 2010 | 03:52 AM
taman86's Avatar
true but you are using a larger volume of air through a small opening which in turn would create a larger amount of air being pushed into the cylinders at a faster rate, think of it like water being pushed from a large hose into a smaller diameter hose through a spout, it will be much faster.
Old Jul 4, 2010 | 03:53 AM
taman86's Avatar
or also you can port the mouth on a stock intake to 80 or 85mm to complement it with a larger tb
Old Jul 6, 2010 | 01:41 PM
RetepNielk's Avatar
I'm going through the exact same question on my 01 WS6. Just put on the SLP lid and smooth baffle and I need to replace the maf. Got on here to find out if the 85 mm was worth it. I keep finding a lot of people saying its crap but for no real reason.
Only thing I've seen being said consistently is that you might lose some low end (which unless you have slicks on is probably a bit of a good thing) and gain on the mid/high end.
I ordered the SLP 85mm this morning ... I'll let you know if I have any problems. Currently have long tubes with free flow cats and already tuned.
Old Jul 6, 2010 | 02:48 PM
john563's Avatar
Ive had mine for about 7years and no problems with it..I hear the same things you do that they are crap..My question is why? The only thing I hear is that a bit harder to tune..But thats what I pay my tuner for..
Old Jul 6, 2010 | 03:26 PM
i added mine along with a FAST and 90 MM TB.
Old Jul 6, 2010 | 04:56 PM
taman86's Avatar
so the poll says three dislike's with no reason why. and i agree with john563, they maybe a bit harder to tune with but if you're paying 500 for a dyno and tune session you better get what you pay for. i had mine with just an intake mod, then pp throttle body, then an 85mm throttle body, then long tubes with ORY and cat back, now switched over to another car with same intake set up but with true duals and no cats, and a fairly aggressive cam and still nothing wrong. i say its a decent mad, maybe a bit pricey for a new one, but in the long run it leaves room for mods and wont have to worry about a choking effect in the intake track with a 75mm.
