installing ls6 intake
Old Jul 3, 2010 | 02:21 PM
svg210's Avatar
Default installing ls6 intake
Hey guys I came up on a good deal for an intake. And my question is... do I need coolant plugs for an ls6, or all I need to do is grind something.
Thanks in advance
Old Jul 3, 2010 | 02:56 PM
99huggerorangeZ's Avatar
Thanks in advance
this is what i did,i wouldnt recommend plugging the rear crossover passages it can lead to overheating of the rear cylinders and causing missfire.
https://ls1tech.com/forums/generatio...over-pipe.html
Old Jul 3, 2010 | 02:58 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
https://ls1tech.com/forums/generatio...old-video.html
https://ls1tech.com/forums/search.php?searchid=11467726
Old Jul 3, 2010 | 03:09 PM
MJs1FastSS's Avatar
chisel all the ribs off the bottom (<10min) and your good..... to make sure is smooth and clean ready to be installed
new gaskets are a must 20 bucks
Old Jul 3, 2010 | 03:26 PM
svg210's Avatar
Thanks guys but the manifold is brand new the seller bougt a fast intake. So the seals are new.
Old Jul 3, 2010 | 03:45 PM
Z28/2002's Avatar
Here is what the bottom of my LS6 intake looked like after I chiseled the ribs off it. I also kept the LS1 coolant lines
Old Jul 3, 2010 | 03:55 PM
svg210's Avatar
Thank you very much, I can just use a small dremel to do this right?
Old Jul 3, 2010 | 05:09 PM
rob69zombie's Avatar
Yes you can. I used a dremel. Like others said, you can chisel it and probably not mess anything up but I'm heavy-handed and wanted to be safe so I just ground mine off. Also, I pulled those 2 foam pads off, ground the tabs off, and used spray adhesive to put the 2 pads back on. Good luck man.
 Michael S. Palmer
Old Jul 3, 2010 | 06:14 PM
svg210's Avatar
What did you do to chisel it a screwdriver and hammer, I'm currently using a dremel but my hand is shaky
Old Jul 3, 2010 | 06:55 PM
conor.davis's Avatar
I used a chisel to chisel it haha any ordinary wood chisel will work.
Old Jul 3, 2010 | 07:15 PM
svg210's Avatar
Imma look it up, I am using a flat head screwdriver right not and its doing well
Old Jul 3, 2010 | 07:21 PM
svg210's Avatar
Old Jul 3, 2010 | 07:26 PM
z99ls1's Avatar
Restricted User
A chisel works good. All I did was chisel the bottom things off and put it on... Be carefull not to break the opsu!
Old Jul 3, 2010 | 07:49 PM
just my.02 but why butcher up a perfectly good ls6 intake. remove the ls1 coolant lines and install 2 coolant crossover pipes and tie in the rear line to the front with heater hose. i also converted over to ls6 PCV at the same time.
Old Jul 3, 2010 | 08:26 PM
z99ls1's Avatar
Restricted User
Because it is wayy easier, less exspensive, and why would you do all the extra b.s when it is fine just to chisel the bottom little peices off? They don't do anything and you can't see it when its installed, so why does it matter? Just go the easy route. It works great
Old Jul 3, 2010 | 09:06 PM
to each his own,just my opinion.
Old Jul 3, 2010 | 11:40 PM
svg210's Avatar
Thanks, but I agree with z99, its not really butchering IMHO, it looks pretty clean, I'm still going to sand the tanned area and paint it or try to blend it in. plus I saved 50 dollars.
so all in all, to each his own
Old Jul 3, 2010 | 11:57 PM
Nemesis350's Avatar
Sorry this is not 100% true... And i'm saying this from experience. ALTHOUGH, i concur that keeping the ls1 coolant lines would be a safeR option. But there's been plenty of ls meltdowns with either setup.
But using the rear block offs isn't going to guarantee catastrophic failure.
Old Jul 4, 2010 | 12:51 AM
z99ls1's Avatar
Restricted User
Yea, I wasn't saying you were wrong, I was just giving my opinion as well.
Old Jul 4, 2010 | 01:01 AM
its all good,dont sweat it. i know were all just trying to help svg210.
