spohn solid mms
Old Jul 10, 2010 | 07:23 PM
500@10psi's Avatar
Default spohn solid mms
any one run these with a stock k member? i want to get these but ive read that you will need a spohn k and the motor will sit higher. dont care about the drivability stuff, just dont want to have any issues with clearance or not fitting. input apriciated kinda need new mounts
Old Jul 10, 2010 | 08:46 PM
WS.666's Avatar
I run them on a stock k-member...no problems at all so far.
Old Jul 10, 2010 | 08:50 PM
02sleeperz28's Avatar
Save on weight and labor and do the k-member also.
Old Jul 10, 2010 | 09:00 PM
gta3uzi's Avatar
Are there any good write ups on K-member replacement? I did a quick google search and didn't find anything.
Old Jul 10, 2010 | 09:09 PM
500@10psi's Avatar
k is like 5 bills tho, still gotta pay bills lol. i just want to be able to take off from a left arrow and not have the headers hit the steering knuckle. did any of you notice if your intake was closer to your cowl i read it moves your motor up a bit
Old Jul 10, 2010 | 10:43 PM
Magic Man's Avatar
Have run Spohn and stock K for years with no problems.My headers do hug the frame a little tighter tho.
Old Jul 11, 2010 | 12:55 AM
The PA racing K-member is cheaper and a nice piece.
Old Jul 11, 2010 | 06:22 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Same here
Old Jul 13, 2010 | 05:29 AM
Cobras_Rule's Avatar
Also running SMM's no issues... no header bang on floor or steering shaft... I would make the same choice again
Old Jul 13, 2010 | 01:56 PM
SS4Luck's Avatar
they do raise the motor about 1", but its nothing to worry about
Old Jul 13, 2010 | 06:33 PM
Ping King's Avatar
you can put some poly mounts in or space the K member pedestal up before going to a solid mount.
Old Jul 14, 2010 | 12:01 AM
sjsingle1's Avatar
they dont raise the engine up 1 inch...........they put the engine up where it was when new......old rubber shrinks
