Slp Header Install
Old Jan 18, 2004 | 11:48 PM
DEPHUDSON's Avatar
Default Slp Header Install
Just Done Slp Header Install On My 02 Ss. This Was My First And It Took Me About 10 Hours With One Person Helping Me. Put the car up on jack stands as high as it would go and Install Went Easier Than I Thought! Everyone Says Slp Is The Hardest To Install?
I Just Removed The Trans Brace For The Passenger Side And Header Slid In. Never Removed Starter Or Coil Packs!!! Anyway Thanks For Everybody's Advice!!!!!!!!!
Old Jan 19, 2004 | 02:16 AM
SLP LS1's Avatar
How's ground clearance? I here a lot of people compaining these days on ground clearance with SLP's headers. I don't know how jet hots are, but I would think SLP would know what they are doing. I'm thinking of getting SLP's headers, so I would like to know!!!
Old Jan 19, 2004 | 02:23 AM
RAMnGO's Avatar
even though my car isn't lowered i haven't scraped the headers yet but i do scrape the mufflers quite often...
Old Jan 19, 2004 | 05:09 AM
soundmaster's Avatar
I've scraped the bottom with the SLP's LT's when going up certain driveramps or a rough parking lot with bumps. Not often though. If you plan on lowering the car, you must get something else. If you look at my car from a distance down below, you can see the parts sticking out.
Old Jan 19, 2004 | 06:34 AM
DD966's Avatar
Ditto, clearance is an issue if you plan on lowering your car. I've had my SLP LTs for 2 years - scraped once.
DEPHUDSON: Well done, it us over 12 hours on a lift.
Old Jan 19, 2004 | 07:37 AM
smokin' joe 00 ss's Avatar
I lowered mine and after 2 weeks I put the stock springs back on since I scraped the headers twice I didn't want to beat them up anymore.
Old Jan 19, 2004 | 10:05 PM
SLP LS1's Avatar
I haven't lowered my car guys, do you think I'll be alright with slp's LT. I would like to see some side pictures of your cars. It would be nice to see the actual ground clearance.
Old Jan 19, 2004 | 10:40 PM
DEPHUDSON's Avatar
ground clearance is low. if you look at car from a distance you can see them. plenty of clearance as long as you dont lower your car. definately tell a difference in power and sound!!!!!!!!
Old Jan 20, 2004 | 05:14 AM
scalemaster's Avatar
I got the same 1's on my car I like them cause they stickout so u can tell i got headers I'm not gouing to drop it so I'm putting so taller tires& wheels
Old Jan 20, 2004 | 06:40 PM
tbyrne's Avatar
We usually loosen the K-member to bring it down a little if it's a tight fit. This gives you a little more room to rotate the header into place.
Tom
T BYRNE MOTORSPORTS
E-mail - tbyrne@tbyrne.com
Order line 1-877-4-TBYRNE
SUPERCHARGER DISCOUNTS AVAILABLE!
