How many people's ORY hits the floorboard?
STF Veteran
I was wondering. If it sets the knock sensor off what happens to the engine? What does it feel like when the y-pipe hits the floor?
Originally Posted by DEPHUDSON
Mine Vibrates Under Passenger Side Seat Only When Turning Left> Any Suggestions? Car Has Slp Lts With Cats And Y.
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
if you don't want to weld for even if it hits after being welded, get a big hose clamp or something similar and put a piece of heater hose around it then clamp it around the y-pipe between it and were it hits the floor board.
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
STF Veteran
Originally Posted by 2002SilverWS-6
Mine hits. Helps me from falling to sleep when I'm banging gears.
mine bangs but doesn't set the knock sensor off. I would think if your knock sensor is going off that your headers themselves are banging the K-member. Your Y pipe shouldn't hit hard enough to set of the knock sensors. Well I hope not.
Originally Posted by 99-LS1-SS
I notched my k-member but, maybe it wasn't enough. ![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
