Confused? :confused:
Old Jan 20, 2004 | 05:37 PM
99-LS1-SS's Avatar
STF Veteran
Default Confused? :confused:
When you put headers on does it make your car run rich or lean?
Old Jan 20, 2004 | 05:44 PM
01PewterWS6's Avatar
I think rich or at least thats how mine smells(pig rich). Only mods i have so far are lid/filter and headers.
Wade
Old Jan 20, 2004 | 06:30 PM
Leatherneck's Avatar
Rich, rich, rich, gas in my oil rich. Get it tuned after headers or you may regreat putting them on at all. Good luck.
Old Jan 20, 2004 | 06:31 PM
SouthFL.02.SS's Avatar
!LS1 11 Second Club
Rich. Cats broke apart. Smoke filled my driveway.
Old Jan 20, 2004 | 06:36 PM
jrp's Avatar
jrp
SN95 Director
that happenend to me only after the 230 install. ****** melted my cat :o
Old Jan 20, 2004 | 06:40 PM
!LS1 11 Second Club
Yeah, happened to me on the way to the dragstrip. Car sounded like a can of jellybeans being tossed around.
Old Jan 20, 2004 | 06:43 PM
jrp's Avatar
jrp
SN95 Director
my car went into limp mode and i had a flashing SES light and smog was comming in through the center console , when i parked it and looked under the car the cat was glowing red. once i pulled the Y the whole front honey comb was gone.
Old Jan 20, 2004 | 06:46 PM
Colonel's Avatar
Sometimes neither. Mine ran the same before and after so far as I could tell. Wideband O2s checked out at 13.3:1.
Moving this to EXTERNAL ENGINE.
Old Jan 20, 2004 | 06:53 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Tons of people run headers without tuning. Lots of people run cams without tuning.
Tuning can be a great thing, but I think too many people see it as a 'must' because of the big internet push that tuning gets. It's only a must in extreme cases, most mild setup cars run decent, fine, or even good without it.
Plenty of H/C & header LS1s were around and doing good before dyno tuning LS1s became common.
Old Jan 20, 2004 | 06:57 PM
RPM WS6's Avatar
Also, those of you blaming rich conditions on melting cats, I don't get that?
It seems odd to me because, back when I used to use cats, it was always & only a LEAN condition or afterfire that would end up overheating, breaking up, or melting my cats. Runing rich never casued that for me... I don't get it?
Old Jan 20, 2004 | 06:59 PM
99-LS1-SS's Avatar
STF Veteran
My car smells like it is running rich. Should I be worried?
Old Jan 20, 2004 | 07:09 PM
RPM WS6's Avatar
Do you have cats? If not, then it's always going to smell 'rich/dirty'. I have spent hours tuning my car for better low end driving and warm starting, and even gone so far (too far) as to lean it out to the point that it would hesitate when getting on the gas from a stop, and even then it still smelled rich/dirty.
Old Jan 20, 2004 | 07:12 PM
99-LS1-SS's Avatar
STF Veteran
Ok that sounds like my problem. Will running rich hurt the motor? And what affect will the HPP3 power program have on my car? I am using the HPP3 PP right now.
Old Jan 20, 2004 | 07:18 PM
RPM WS6's Avatar
Depends on how rich. If your oil is dripping with gas, then yeah that's bad. A little hint of gas on the dipstick is not a big deal though, all my cars (modded or not) always have that. But people perceive things differently though, what is 'a little' to some, is 'a lot' to others sometimes. Never heard of headers alone causing anyone to run rich enough to do any real harm, it's just that you will not be seeing your full power potential if it's rich.
The HPP will raise timing....
Old Jan 20, 2004 | 07:20 PM
99-LS1-SS's Avatar
STF Veteran
Pretend that I am a retard.(not a far stretch) What will raising the timing do?
Old Jan 20, 2004 | 07:26 PM
RPM WS6's Avatar
Simply put, raising the timing will generally give you more power right up to the point that you begin to detonate. Detonation due to more timing can usually be faught with lower temp t-stats and/or fan settings. Not to say that the extra timing will cause you to detonate, but it might if you're still using stock fan settings keeping you at or above 220*...
