What Underdrive Pulley for an LS1?
Old Jul 27, 2010 | 08:40 PM
Cheatin' Chad's Avatar
I like ATI. high quality,proven damping ability. Makes more power and is actually tunable for the RPM range you can run in. They offer a steel 7.5 and an AL 6.5 thats underdriven. Even without the underdrive they are proven to make more power by properly damping crankshaft vibration.
I believe it was the GMPP 572 crate engine that picked up over 10hp with nothing but a swap to an ATI damper.Not an underdriven pulley either just the straight swap.
OP: A problem you may encounter is damaging the threads in your crank if you use the old bolt to draw the new damper onto the crank. Get yourself a piece of M16x2.0 "all thread" thread that fully into the crank hand tight and use a nut and hardened washer to press the damper on.When this is done put your new factory bolt or preferably and ARP bolt in and torque appropriately. Holding the crank still while applying this torque can be done alot of different ways do a search. I'm not recommending it but I've seen plenty of guys with 6speeds stick it in 6th and apply the e-brake then give it hell. I think Kent Moore makes a flywheel holding tool for this purpose. It's your call.
Old Jul 27, 2010 | 09:04 PM
TXZ28LS1's Avatar
running an ASP pulley here..no problems at all.. the SLP under drive pulley looks like a good piece.
Old Jul 27, 2010 | 09:29 PM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
My C5 powerbond with our reusable crank bolt.
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Jul 28, 2010 | 01:01 AM
You guys with the 25% underdrive having charging issues at stock idle?
Did any of you swap in a smaller alternator pulley?
Old Jul 28, 2010 | 03:46 AM
ls1 1990 VN's Avatar
No & No...it doesn't sit there idling for long, why would you want it to?
I've had no issue with my charging system at all. Pulleys been on now for 4yrs
Old Jul 28, 2010 | 11:49 AM
Anthony Williams's Avatar
Originally Posted by Scoggin Dickey
It's actually a very popular mod, and is very well worth the money. We sell you guys on the forum the powerbond unit for a great price, and it includes the new shorter belts you will need and your choice of either a new stock bolt at the quoted price or our own reusable aftermarket bolt for $10 more. We also offer ATI and have had perfect results with both brands.
ME TOO! for the Powerbond w/ belts.
Old Aug 1, 2010 | 04:10 PM
Mikey 97Z M6's Avatar
I just found two cracks in the rubber isolater and the outer part spins about 3/8-1/2" back and forth. It's an ASP pulley but it's also about 8-9 years old.
SDPC, I'll be placing my order for a Powerbond pulley in the next couple days. What's the part number for an 99 Fbody?
Mike
Old Aug 1, 2010 | 06:53 PM
Mike
link in my sig. Fbody is 1480ss25
__________________
Old Aug 2, 2010 | 03:08 AM
FBodyPerformer's Avatar
Another that attests to the ASP. Ran it on my car for over a year, no problems with temp or battery (no alternator pulley). Good performance. Can't wait to put another one on.
Old Aug 2, 2010 | 06:40 AM
TORCHD 02 TA's Avatar
Originally Posted by 02*C5
Why do you want an under drive pulley.
When you look at it is it worth the money for the HP gains.
Most UD pullies are around $300 or so dollars for a few HP maybe 7rwhp.
It will make your water pump run slower and thus your fans will be running constantly specially in stop and go traffic.
I can keep going if you want. Alone reason 1 should be enough to deter you.
They make really good paper weights and that's it.
Hell get a bigger and better maf, or get a good TB and don't forget you are going to have to do the alternator pulley also.
Dude where did you get your info If you're getting jsut a crank pulley, that has no effect on your water pump.. Ohh and btw. the stock MAF is goo up to 500 HP...
Originally Posted by blackls1ta00
asp here no problems whatsoever,the gains are good with a cam too.
I've had my ASP UDP for 9k miles and I too did it while I did my cam swap
Old Aug 2, 2010 | 06:41 AM
NO and NO
Old Aug 28, 2010 | 09:55 AM
  #32
Ever drive in Chicago tollway traffic?....You can be creeping along at idle for hours.
Old Aug 28, 2010 | 09:57 AM
  #33
Originally Posted by vettenuts
Avoid ASP, there have been a number of documented timing chain failures associated with the ASP. Don't forget, the part you are replacing is a "harmonic damper", not a pulley. As you go smaller in diameter to get the under drive capability, you lose damping capability. The best two out there are ATI and stock, and ATI is a 10% under drive.
They make a stock diameter damper for the F-body FEAD as well.
105-917264 : ATI Serpentine Series Damper Assembly with Hub & Aluminum Shell, Stock Diameter w/ A/C Pulley, LS1 F-Body /
Old Aug 28, 2010 | 11:32 PM
  #34
chevynation's Avatar
https://ls1tech.com/forums/generatio...ter-broke.html Scroll down to post #12.
I'm swapping my ASP 25% underdrive for an ATI as soon as I can.
Old Sep 8, 2010 | 09:42 PM
  #35
vitalogy44's Avatar
How hard/tight is the install?? Timewise, what am I looking at?? Also, is an UD upgrade moew important after a cam swap??
Old Jan 8, 2011 | 10:35 AM
  #36
Edrummr's Avatar
Default Crank pulley bolt
I ordered SDPC SKU KPBU1480-SS25 and I recieved GM crank bolt P/N 12557840.
The kit description says this kit includes "the SDPC high performance 8740 reusable balancer bolt". The bolt I recieved doesn't look like the one in the above picture. Is the bolt I recieved a high performance reusable bolt?
Thanks for any input,
C
Old Jan 8, 2011 | 12:34 PM
  #37
99Bluz28's Avatar
C
The only reusable crank bolt I know of is the ARP crank bolt, I'd call SPDC about the bolt.
FYI, the ARP reusable bolt is about $20, the one time GM bolt around $5..
Old Jan 8, 2011 | 12:37 PM
  #38
Edrummr's Avatar
ok. Will do. Thanks 99blu.
C
Old Jan 8, 2011 | 01:12 PM
  #39
C
PM me your name and info and we will get this fixed for you. We will ship the correct one out right away.
We have an ARP style reusable bolt as well, so we offer the GM bolt, our reusable bolt, and the ARP bolt. In the pic of my engine above, that black 12pt bolt is the SDPC bolt.
__________________
Old Jan 8, 2011 | 01:24 PM
  #40
2QUIK4U's Avatar
I have used ASP pulleys and Powerbond. Both seem to work well. Make sure to get an ARP bolt.
