Descreen or don't descreen Is it worth any extra HP or better flow to descreen the maf on a ls1? I noticed these don't snap out like the lt1's did so I didn't want to mess anything up by smashing this one out. Any thoughts? Bad idea? |
This topic has been discussed MANY times! In my opinion, it's not worth it. Many people have done it though, and have not had an issue with it. I've seen a couple of things on my MAF screen that the air filter has not caught so I look at it as a final filter before it goes any further. It's your call. Here is just one thread out of the many about this topic.https://ls1tech.com/forums/generatio...g-you-maf.html |
search or dont search? |
don't do it, not worth anything and if you fuck up your maf you wont be happy |
I took the screen off of my LS1 and I've never had any problems with it. It sounds different when I rev it up though... you hear alot more suction if you will... |
I think its up to you. I have been running descreened for 2 years. No issues at all. But since the previous owner did it I have no idea if it did anything. |
I was going to do this until I looked at it and seen the screen had caught a bug or two, some pine needles, and one of those little helicopter things that fall off trees. |
Leave it alone. 0 gains from descreening. |
Originally Posted by Latch
(Post 13660102)
Leave it alone. 0 gains from descreening. bump stop mod doesn't worn either right? or ram air kits? if you believe pulling an obstuctuon from the intake path doesn't help maybe putting one in like a tornado will help? all the little stuff adds up :) |
Haven't had a screen in mine for about 6 years, zero issues. |
Not gonna say it won't help, but I wouldn't do it. Something could make its way to the MAF. Without the screen it will go right through. Not a good situation. People have found all kinds of stuff on the screen. Bugs,twigs, etc.. |
several respected opinions have claimed it can conflict with the MAF calibration/tune |
Originally Posted by LS1WS6dreamer
(Post 13660435)
Not gonna say it won't help, but I wouldn't do it. Something could make its way to the MAF. Without the screen it will go right through. Not a good situation. People have found all kinds of stuff on the screen. Bugs,twigs, etc.. removing the screen will help but it can tweak the tune so it should be adjusted or done before a tune, just like getting an 85mm maf to replace a stocker... |
Originally Posted by chrs1313
(Post 13660389)
Incorrect...:nono: bump stop mod doesn't worn either right? or ram air kits? if you believe pulling an obstuctuon from the intake path doesn't help maybe putting one in like a tornado will help? all the little stuff adds up :) https://ls1tech.com/forums/texas-mem...yed-motor.html ...Gained a bolt into his motor that would have been stopped by the screen if he had one. |
(Post 13661663)
Oh there are "gains" to be had from de-screening, the guy in this thread... https://ls1tech.com/forums/texas-mem...yed-motor.html ...Gained a bolt into his motor that would have been stopped by the screen if he had one. I guess everyone including me is screwed who is speed density tuned :) also don't mention this to the carb guys! |
I did it and had no issues. Been descreened since like 03. lots of trips to the track and thousands of street miles...of coarse I was going for a stock internal record and was trying to get every ounce of HP i could get..fyi:D:D |
A stock screened maf will only flow about 800cfm if I remember correctly, as a descreened maf can flow over 1000cfm. Food for thought. And this thread has been started WAY to many times. It's the same every single time, half say do it, half say don't do it. Come to think of it. I have been wondering if it's worth it to descreen your maf or not. I think I'll make a thread about it next week...:jest: |
(Post 13661663)
Oh there are "gains" to be had from de-screening, the guy in this thread... https://ls1tech.com/forums/texas-mem...yed-motor.html ...Gained a bolt into his motor that would have been stopped by the screen if he had one. |
Originally Posted by ShortChevy
(Post 13662819)
Wow, really? I guess sense I am speed density I should put a stupid ass screen in the bellows or something to stop things an air filter is designed and used for. My car's my daily driver, and I am not rich enough to replace a blown motor because something stupid like that happens. I'm just sayin. Why would cost-cutting GM spend the money to put a screen in the MAFs if all it did was obstruct airflow? |
I believe the engineers intent was to straighten the air flow across the metering sensor. And for that reason, personally, I'd leave it alone. |
| All times are GMT -5. The time now is 06:40 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
