New LSX dyno #'s
Shawn
After many pull's I got the A/F back to 12.8-1 to 13.1-1..Then I put on the LSX and surprisingly that was the tune it liked.I tried all different fuel and timing changes.Also the air sucked.About 15 degree's outside and the air was thin.My best dyno pull before was 432hp in 70 degree heat.Thats why I'm more interested in the gains over the LS6 rather than the over all HP.It gained torque everywhere and up to 15lbs in some spots.The hp was higher acroos the range,but more so above 4500rpm..
I did spend an hour cleaning up the runners a bit,but from what I've seen,it looks like the inlet could use some work.I really believe the TB and MAF is holding back power now..
Also when I ran through the SLP dual dual I lost 15hp/20tq across the rev range..FYI
Did you have to make many tuning adjustments with the swap?
Soon I'll be testing the 90mm setup on my car.I will also try out a SLP 85mm TB at that time,then I might try to port it to 90mm and see if it helps.
I'll wait till someone dyno's a full bolt-on internally stock LS1 with the 90mm LSX intake before I buy one. I'm still on the LS1 intake so it should be a huge improvement no matter what
