how to disable automatic headlights?
Old Aug 9, 2010 | 08:14 PM
KSA SS's Avatar
Question how to disable automatic headlights?
I have a 2000 camaro ss and im trying to keep my light from turning on automatically? any idea how?
Old Aug 9, 2010 | 08:26 PM
johnp94's Avatar
Theres a big write up in electronics on the how to's. FREQUENTLY ASKED QUESTIONS. It is listed step by step how to do it. Sounds real easy. I'm going to do it the light switch way by cutting the orange wire. I haven't read the post in a while but gonna do it this week.
Old Aug 9, 2010 | 08:28 PM
johnp94's Avatar
I see you only have one post. Where are you located. I didn't see if you introduced yourself on introduction page. Welcome, Where are you located.
Old Aug 9, 2010 | 08:32 PM
djfury05's Avatar
pop the dash pad off and locate the 2 wires that go to the light sensor (located near the security light) and cut the 2 wires. I taped mine with electrical tape so they wouldn't come into contact with each other. Another option is to use a Scotch lock. 2 second job.
Old Aug 10, 2010 | 03:09 AM
KSA SS's Avatar
thx guys for your help
Old Aug 10, 2010 | 03:13 AM
KSA SS's Avatar
thx man,,,I didnt really notice the introduction page i will go ahead and post there..Im Ahmed from Saudi Arabia and im located in Arkansas in the mean time
Old Aug 10, 2010 | 01:25 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
https://ls1tech.com/forums/2743521-post6.html
Old Aug 10, 2010 | 01:36 PM
Gordon0652's Avatar
Wrong Section. And there is a write up here somewhere. Look up DRL.
Old Aug 10, 2010 | 01:37 PM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
Pry up the dashboard cover (doesn't take much pressure, just ease under it). Right in the center where your flashing LED for the alarm system is, there is a photo-sensor. Disconnect it, and put any old strip of wire across the pigtail going back into the dash. That'll give it the continuity and the vehicle will think it is bright out all the time. Button the dash back up, and try to remember to turn on your headlights in the evening and at night so you're not one of "those" guys
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Aug 10, 2010 | 05:16 PM
KSA SS's Avatar
Done with it I Appreciate it and thanx for your help guys,,it was fairly easy
Old Aug 10, 2010 | 09:34 PM
senicalj4579's Avatar
How dare you not introduce yourself! Thats ok I never did either oh well
