The Best Spark plugs?
Old Jan 22, 2004 | 08:59 PM
CamaroSS's Avatar
Default The Best Spark plugs?
Which are the best to get......and if there is any sort of gain.
Old Jan 22, 2004 | 09:09 PM
WS6FirebirdTA00's Avatar
ngk tr55 do a search that is 90% of what u will see
Old Jan 22, 2004 | 10:16 PM
Colonel's Avatar
TR-55s and TR-6s are the most common choice. I find they idle well and that's why I like 'em. The TR-6 is one range colder than the TR-55 and is the most popular choice for running nitrous. I like it for running NA as well because it helps in fighting detonation. I find that I can run just a smidge leaner at WOT without pinging and I like that. BTW, the TR-6 comes gapped at about .039 instead of the .055 or so that the TR-55 comes gapped at. I'd re-gap them to about .045-.049 for NA use (a narrow gap can cost you just a couple of ponies.)
As far as there being any REAL HP difference between plugs, no.
Old Jan 22, 2004 | 10:22 PM
jerflash's Avatar
2001 and 2002 sould come with denso iridiem plugs and they are the best that you can buy
thats what i have heard i will see when i take mine out when i put headers on
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Thumbs up
Yep. They are cheap to buy, last quite a while, and work great.
jrp's Avatar
jrp
SN95 Director
:BS:, just look down at that thread about the denso's that offer 12hp from a plug swap
but seriously, cant go wrong with the NGK's, im running the tr55's gapped @ .055 and have no problems or complaints with them
Old Jan 23, 2004 | 12:09 AM
deznuttzz28's Avatar
ngk tr55 works great!!!
Old Jan 23, 2004 | 05:21 AM
Slowhawk's Avatar
LS1Tech Sponsor
NGK TR55 here..I've run into too many problems with the stock Denso's in customers cars
Old Jan 23, 2004 | 06:02 AM
JohnnyStorm's Avatar
Yet another TR55 fan. I left them gapped at .055 the way they came, and they are great compared to the Bocsh platinums I took out. Fixing the #4 coil pack didn't hurt either.
Old Jan 23, 2004 | 06:40 AM
CamaroSS's Avatar
I think any gain I would see would be frmo an old battered plug, to a brand new clean plug. At around what mileage should I change them?
Old Jan 23, 2004 | 06:55 AM
RPM WS6's Avatar
I pulled my stock ones at about 5K miles, and was already missing one or two of the platinum tips/disks or whatever you want to call them.
NGK TR55s should last at least 20-30K depending on what type pf driving you do. TR6s about half that, from what I've heard....
