Is this possible????
Old Jan 23, 2004 | 07:06 PM
99-LS1-SS's Avatar
STF Veteran
Default Is this possible????
I just installed a set of Pacestters and a ORY. It feels like my car hits the rev limiter now. Can changing the headers cause something like that?
Old Jan 23, 2004 | 07:26 PM
T-maxx's Avatar
You say it " Feels like it hits the rev limiter " ?? Unless you had your car tuned after the install and the rev limiter was changed it should be the same. It might be banging or rattling under the car. More info would help.
Old Jan 23, 2004 | 07:36 PM
99-LS1-SS's Avatar
STF Veteran
I have changed the rev limiter with HPP3 but way before the header install. The car pauses between shift just a little now. My car has ALWAYS shifted fast and clean. I have a torque converter and a shift kit. If you listen to my car shift it sounds like someone changing gears in a manual. The only thing that has changed is the headers and y-pipe.
Old Jan 23, 2004 | 07:55 PM
jrp's Avatar
jrp
SN95 Director
headers and Y wont effect your shifting. only pcm tuning can do that. i think you have to have a record for the amount of threads you've started since your LT install.
Old Jan 23, 2004 | 08:21 PM
foff667's Avatar
LS1TECH Sponsor
ive actually bumped the rev limiter on the 2-3 shift 3 times now since my header install 3 weeks ago and never once hit it without the headers so id say yes it is possible...kinda like when people go to different gearing and the computer cant compensate for the eccessive acceleration and taps the limiter...im just gonna bump the limiter up once i get my heads/cam on and probably keep the shift points around the same...give or take a few hundred rpm.
lata
Bill
Old Jan 24, 2004 | 03:59 PM
MARKSZ71's Avatar
i just put headers on my car and dam everything feels diffrent
Old Jan 25, 2004 | 11:05 AM
huggerr1's Avatar
LT headers changed my rpm band. Hit the rev limiter several times before i realize it
Mycar felt like it was still pulling into the 6es. I usally shifted out around 55-56 before.
I need to get to a dyno and see whats up. I did the slp LT y-pipe hi flow cats and loundmouth all at the sametime
huggerr1's Avatar
I need to get to a dyno and see whats up. I did the slp LT y-pipe hi flow cats and loud mouth all at the same time
Old Jan 25, 2004 | 07:01 PM
99-LS1-SS's Avatar
STF Veteran
If I could get an answer that suits me I wouldn't have to keep posting the same question different ways. Sorry if it bothers you. I am trying to learn something and until this post I wasn't sure of what was going on. Thanks to all who answered.
Old Jan 27, 2004 | 03:51 PM
WILWAXU's Avatar
Wouldn't hurt to check your tranny fluid level either
Old Jan 27, 2004 | 07:42 PM
98TA86's Avatar
same thing happend to me on 2-3 shift since my LT's. I got the tranny fluid serviced and changed but havent gotten a chance to get on it from 2-3 yet.
