01 Trans am odd starting issue
Old Sep 8, 2010 | 11:48 PM
zaner's Avatar
Default 01 Trans am odd starting issue
01 Trans am, auto 75,000 miles....bone stock, been pampered all its life. When you put the key in and turn the ignition forward to start it cranks and cranks but wont start....strong cranks but not so much as a sputter. Key back to normal and try it again and it immediately bangs off and runs without a hitch. Is this a fuel pump or regulator issue?
Old Sep 9, 2010 | 12:08 AM
PowerShift408's Avatar
Next time you start it, turn the key to accessory and listen for the fuel pump to prime. Once it does, start it. If it starts fine after doing that, it's probably the fuel pump.
I have a friend that had a similar issue, and it was neither, can't remember what it was though. It was very simple though. I will check with him and let you know.
Old Sep 9, 2010 | 12:13 AM
Alright, my friend's problem was the ignition relay. You could give that a shot. But if you try to start like I said and it fires up after you let it prime, I'd about guarantee that it's a fuel pump.
Old Sep 9, 2010 | 12:23 AM
Pwebbz28's Avatar
I would point towards ignition relay as well. Had the exact same problem with mine.
Old Sep 9, 2010 | 12:27 AM
Atomic02's Avatar
It could also be the passkey sytem acting up
seen several of them go haywire
try a different key if you have one
Old Sep 9, 2010 | 12:38 AM
PWebbz, I haven't seen you on here in awhile. I think I sold you a shift **** awhile back. I'm the guy that bought Brandon's car a few years back.
Old Sep 10, 2010 | 08:10 PM
zaner's Avatar
Thanx for the replies
Old Sep 15, 2010 | 01:17 PM
whtrashferrari's Avatar
Default lots of things
Our cars are gonna be wiring nightmares in 20 years
I had a fuel pump relay cause that issue on my old 98
bad pcm lol too many things it could be...
hope you get it nailed out dude!
fuel pump idea is a great place to start .. you can use a oldschool timing lights inductive pickup on one of the wires to
see if your getting spark or do the Pollock method and use a screwdriver to a ground those coils will zap yah good
though...
