FAST 92 questions
and I havn't had any problems with using them mine is a FAST 90,,but I don't think that matters.Also if you have the LS6 rear coolant block off pieces and the front piece you'll be fine using those.
I most certainly agree the front coolant line does need to be bent down (soft, plastic, dead-blow hammer comes to mind). I fyou buy a kit new you get button head screws to clear the bottom in the intake valley cover area.
In general swap over all your stuff, Disassemble the LS6 once its out of the car. Use Tape (duct, electric, masking, painting) to hold up the rear half of the intake bolts. Disconnect the vaccume hose from the brake booster and route around the back to avoid breaking the oil pressure sensor. Disconnect the MAP harness before final pull. Use only Plastic fuel line disconnect too. IF you break the lock it is 60-80 for a new fuel line from the Dealer.
Scroll down you'll see it.. but just because they have it listed doesn't mean it's in stock, or maybe they just forgot about the listing.
You can find one used on here with little to no miles for a much better deal. I bought mine which was brand new pretty much, only 50 miles, and it was already ported, for $700 shipped. The shipping was about $40, so the intake itself was around $660. There are better deals to be had even still if you search/wait long enough.
In general swap over all your stuff, Disassemble the LS6 once its out of the car. Use Tape (duct, electric, masking, painting) to hold up the rear half of the intake bolts. Disconnect the vaccume hose from the brake booster and route around the back to avoid breaking the oil pressure sensor. Disconnect the MAF harness before final pull. Use only Plastic fuel line disconnect too. IF you break the lock it is 60-80 for a new fuel line from the Dealer.
You must talking about the MAP sensor and MAP harness on the back of the intake lol? Don't want anybody confused
http://www.ls1howto.com/index.php?article=5
Pics and write up of the entire process on how to remove and reinstall. I've got my Fast 90 off right now and it was pain free following those instructions.
.Thats what I would suggest doing↑↑↑↑ I also know several other people that have done this with no problems even over two years worth of DD driving.
