Catted vs Offroad Longtubes, which would you prefer
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
The headers themselves don't have the cats, though, so the question is also whether you'll be running a y-pipe or true duals.
For an f-body with a Y set-up
Depending on what setup for the exhaust im using. As for now, ill stick with no cats on a y pipe setup.
Something with a full size muffler like Magnaflow or Hooker, you can get away with not having cats and still be without the majority of the rasp these LSx motors produce.
But if you're running a catback with a resonator (Loudmouth Systems) or chambered exhaust (GMMG), I believe cats are the way to go to keep these setups from becoming overpowering.
I guess there seems to be one exception to this rule though. I know TORCHD 02 TA is catless with his GMMG setup on his T/A. He also has a chambered Powerstick in his I-pipe to tame the rasp.
My $.02.
FLP used to be like that, I had a set in 2000. They even used vclamps on their stuff. I regret selling them sometimes because of the ease of swapping out the cats.
Cats are not mufflers. If you've got a problem with the sound, put resonators in. They're cheaper and flow better.
If you've got a problem with rasp, well, stop running a damn y-pipe. I have cheap true duals that sound great, fit well, rarely scrape, and are all stainless.
