Difference Between 98-99 and 00 Headers?
Old Jan 28, 2004 | 08:45 PM
Ferocity02's Avatar
Default Difference Between 98-99 and 00 Headers?
I know that the only difference(I think) is in the EGR tube. What exactly is the difference? Can the 00 headers be modified for a 99? Thanks.
Old Jan 28, 2004 | 09:22 PM
jrp's Avatar
jrp
SN95 Director
search
98-99 have the egr and air tubes in a different position then the 00 headers. 00 has the air tubes the same as the 01+ and its own egr setup.
you can modifiy the pipes or just buy the headers and !air/!egr.
Old Jan 28, 2004 | 10:00 PM
Ferocity02's Avatar
I did to a search and got nothing. You basically repeated what I said. How does the EGR tube need to be modified? Bent, shortened? Ect... And removing the AIR and EGR is not an option by any means. Thanks!
Originally Posted by jrp
search
Old Jan 28, 2004 | 10:01 PM
jrp's Avatar
jrp
SN95 Director
it needs to be bent to fit the hook up. simple as that.
Old Jan 28, 2004 | 10:06 PM
Ferocity02's Avatar
What about the AIR tubes, any bending there?
Old Jan 29, 2004 | 02:26 AM
Spooln's Avatar
Default 98-99 headers
Hey Fer,
Our 98-99 headers are inferior to the 00-02 headers. The 98,99 have the drivers side which is a log design and the passenger side is more of a Y type set up. The 00 headers have provissions for the EGR setup but you would have to use the 00 EGR tubes. Also you need the 00 Y pipe and cats from what i understand. I am considering upgrading my 98 manifolds to the 00 EGR set up. I think it would be a cheap upgrade as compared to a set of high dollar headers. I searched and have found many LS1s going in the high 11s and low 12s with stock 00-02 exhaust manifolds. It just seems that the 00-02s are always running 3-4/10s faster then the 98-99 cars, so it has to be in the intake and exhaust manifolds. I also searched to see how much difference in power can be had from upgrading from factory 00-02 manifolds and with stock heads and cam, i seen were cars only picked up an average of 12-14hp and tq. That gain to me is not worth 1000 bux. Sure a good set of LTs will help out with future internal upgrades but at this point having a fast low 12 sec street car is my goal.
