Fast 102 too big for a 383?
Old 12-28-2010, 12:49 AM
hitmanws6's Avatar
But the FAST 90/92 uses the LS1/6 style injectors?
Because it was designed off the LS1/6 intakes, the 102 is based off the LS2, hence the use of LS2 injectors. LS2s are shorter and enter the intake at a different angle. Thats why there is a spacer needed for LS1 injectors
Old 12-28-2010, 01:01 AM
LilJayV10's Avatar
Good to know!
Old 01-06-2011, 01:42 AM
Black98Z28's Avatar
Now what kind of injectors should I get? Im not too familiar with the differences of flow matched, low impedance etc
I am looking at these, minimum for my setup calculated at 46# injectors, I would like to have enough injector and not have to worry about duty cycles.
http://www.byunspeed.com/product_inf...oducts_id=7233
or any other recommendations would help out aswell.
Old 01-06-2011, 01:56 AM
hitmanws6's Avatar
Somewhere in the area of 48-52lbs/hr would be a good minimum. Those 50s would be good. You could even get away with the 57lbs/hr, those would give you some room to grow as well
Old 01-06-2011, 09:07 AM
Black98Z28's Avatar
So is an injector an injector? I will either get the 60lb Siemens or the 57lb FAST's in that case.
Quick Reply: Fast 102 too big for a 383?
