Motor Mounts
Old Jan 30, 2004 | 05:22 AM
JOHN LAWSON's Avatar
Default Motor Mounts
What type of motor mounts to use in a F-body?
Old Jan 30, 2004 | 06:05 AM
SSactionLs1's Avatar
i have prothane mounts sitting here...they are 49 from thunderracing.com
Old Jan 30, 2004 | 08:07 AM
quickWS6's Avatar
Spohn/Madman solid mounts. They add room, drop weight, don't add any more knock, look nice, and they don't add any harshness in the ride.
Old Jan 30, 2004 | 11:28 AM
Nasty N8's Avatar
Madman won`t sell them any more cracking blocks. Use Prothane urathane mounts. We also stock them.
Nate
Old Jan 30, 2004 | 11:36 AM
KGSloan's Avatar
here's a pretty good thread on the poly motor mounts:
https://ls1tech.com/forums/showthrea...t=motor+mounts
Old Jan 30, 2004 | 03:42 PM
Nate
Thanks, Nate. I'll call you tomorrow to see what all I need, Thanks John.
Old Jan 30, 2004 | 04:40 PM
samz28's Avatar
get an old pair of mounts before you do the prothane. That way you can make the prothane (they use the existing clamshell) before you start your endeavour. maybe some shop can throw you some old mounts for free.
i didn't know the prothane required the existing clamshells till i read the docs. i just let the mechanic handle it.
Old Jan 30, 2004 | 05:13 PM
quickWS6's Avatar
Nate
I only heard of a couple of guys that cracked a block with them. One was Harlan, and the other was one of Madman's cars. If I was pulling that kind of power, I'd go to a motor plate anyway. I never heard of any car that ran slower then low 10s have any problems.
 Michael S. Palmer
Old Jan 30, 2004 | 05:35 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I am running Prothane motor mounts.
Old Jan 30, 2004 | 08:17 PM
Fulton 1's Avatar
Prothane mounts here too. Install can be kind of a PITA, but very worth it IMO. FWIW, I noticed very little difference between the driver's side only mount and both poly mounts.
Old Jan 30, 2004 | 08:19 PM
MADMAN's Avatar
LS1Tech Sponsor
None of my cars cracked blocks. I just feel a motor plate is safer.
__________________
www.madmanandcoracing.com
225-343-9029
Old Jan 30, 2004 | 08:43 PM
Ron@Vengeance's Avatar
Ive been 9.90s several times with Brians(Madman) solid mounts. Dont really notice theyre there. I will be going with a full plate with my new setup though..
Old Jan 30, 2004 | 09:05 PM
Mike K.'s Avatar
I think I am gonna swap out for some prothane mounts while my engine is out. I may as well,, plus my motor was bouncing around pretty bad so this should help.
Old Jan 30, 2004 | 11:03 PM
Street Racer's Avatar
I have had Spohns solid mounts on my car for almost a year and no problems....
Old Jan 31, 2004 | 06:45 PM
Thats part of the problem, I bought the car as a roller. Some of the parts like mounts I didnt get. So the search is on. Thanks John.
Old Feb 2, 2004 | 02:22 AM
Dope's Avatar
It takes 5 mins to swap them out. If you can do the rest of the work (which is 100x harder), why let a mechanic swap out the mounts from the clamshell? Seems backwards to me...
Dope
Old Feb 2, 2004 | 02:50 AM
finalymodded's Avatar
I have poly mounts also. changed them at same time as I swapped motors so it was pretty easy. I noticed some increase in vibration, but I installed the poly tranny mount at same time so that could be the culprit.
Old Feb 2, 2004 | 07:25 AM
Reckless's Avatar
Super Moderator
Let me know if you need some help buying some mounts from ebay or something John. OBTW, John will be transplanting his Cartek 427 from his 10.4 2000 C5 into what used to be Sean Freese's car.
