ud pulley worth it?
Old Oct 25, 2010 | 10:46 PM
onebadassws9's Avatar
Default ud pulley worth it?
I was concidering an underdrive pulley 25% is it worth the money and how kinda power do you get? or should i say save. i have a lid long tubes tune and 150 shot
Old Oct 25, 2010 | 10:51 PM
grimlock34's Avatar
i got that pulley and could deff notice the car pull especially closer towards the red line. i dont have any numbers at the track but id say its worth it unless your gonna turbo or sc it.
Old Oct 26, 2010 | 09:55 AM
thunderstruck507's Avatar
do it during a cam swap and buy it used...otherwise, it's less cost effective
Old Oct 26, 2010 | 10:00 AM
senicalj4579's Avatar
I heard that it messes with your electrical or something to that effect. Any of that true?
I know its deff an expensive mod for the power gained but idk if its worth if
Old Oct 26, 2010 | 10:08 AM
there is a myth that it causes low charging from the alternator, but I don't recall anyone on this site having trouble with it...mine certainly didn't change
it is a very minor mod, .1 or less in ET but you should notice the car rev slightly quicker...won't feel the difference
like I said, do it during the cam swap and buy it used for $120 or less or don't worry about it IMO
Old Oct 26, 2010 | 10:16 AM
00blacka4's Avatar
I write checks with my mouth that my ass can't cash
anything you do is worth it....i noticed the car reved alot faster and am very happy with my powerbond
Old Oct 26, 2010 | 10:27 AM
Jon@Texas-Speed's Avatar
Worth about another 8 HP to the ground. Shouldn't have any problems w/ electrical unless you have a big stereo system. You can always put an overdrive alternator pulley on it to stop that. Also, if you have a cam in the car the idle will be raised so you won't have a problem either. I would do it.
Jon
Old Oct 26, 2010 | 10:35 AM
Z06 Steve's Avatar
these balancers are a press on fit with the LS1/LS6's I would only go new lots of junk out there
Old Oct 26, 2010 | 11:17 AM
Jon
What about on a hot summer day and the ac,fans,tranny cooler fan,and stock radio are going at same time?
Old Oct 26, 2010 | 11:30 AM
Newer cars have more stuff obviously but I run 2 large high draw fans, lights, windshield wipers, and a 12" sub with a 200watt rms amp. Never had trouble.
I have a powerbond 25% corvette pulley. Used on ebay for $120 shipped.
Old Oct 26, 2010 | 12:19 PM
Thats good stuff right there. I may have to order one.
Old Oct 26, 2010 | 12:25 PM
Joshiedoom's Avatar
Whats everyones average ET gain after this while were on topic?
Old Oct 26, 2010 | 12:53 PM
Well Jon says roughly 8hp so thats probly around .1 gain
Old Oct 26, 2010 | 06:27 PM
grimlock34's Avatar
im w jon at texas speed. the 8 hp was noticeable, it revd quicker and pulled a little bit harder. it may not be like throwing a set of gears or long tubes but its all in what your wanting to get out of your car.
Old Oct 26, 2010 | 06:41 PM
RJB01camaross's Avatar
Defidently worth it, but like what has already been said do it during a cam swap since it has to come off anyway.
Old Oct 26, 2010 | 06:48 PM
01SS99red's Avatar
Def. worth the money easy quick bolt on.
Old Oct 26, 2010 | 06:54 PM
ULTIMATEORANGESS's Avatar
i noticed a little bit from mine. no problems with it.
Old Oct 27, 2010 | 12:37 PM
taman86's Avatar
not trying to high jack here but ive been thinking about one also and what all si required for the pulley swap, and hard is it?
Old Oct 27, 2010 | 12:46 PM
Bramlok's Avatar
Nobody is going to feel a 8 hp difference. I think these are a waste but like someone else said, if you're doing a cam swap or engine build and can find one for cheap, it won't hurt to put one on. Otherwise I wouldn't waste my money on it.
Old Oct 27, 2010 | 03:19 PM
philsblwnz28's Avatar
DO NOT PUT THE UNDERDRIVE ALT. PULLEY ON. Get the overdrive pulley. TRUST ME, I KNOW FROM EXP....
