HELP: what lid and MAF???
Old Nov 6, 2010 | 10:38 PM
  #41
djfury05's Avatar
Originally Posted by LSxWS.6
is this it??????? Caspers LS1 MAF to 3800 MAF Pigtail
http://speed-eng.com/store/caspers-l...l-p-10298.html
This is what you want bro, http://www.hawksthirdgenparts.com/ad...readapter.aspx
Originally Posted by disc0monkey
well was at the sponsor CSP today and we tested stock lid, descreened stock MAF, to a SLP lid and z06 85mm, and gained 20hp/18ftlbs of torque. on basically stock car with a EPS cheater cam.
Damn now that's what I'm talking about! Great results from simple add ons.. I bet your throttle response improved as well
Old Nov 7, 2010 | 08:17 AM
  #42
disc0monkey's Avatar
Here is the whole story. Andrew at CSP confirmed my thoughts on the 85mm MAF as he sees about 8hp average gains on cars he does. HP/$ this is a great mod. Even without the screen he nailed the tune its butter smooth.
https://ls1tech.com/forums/dynamomet...l#post14089188
Old Nov 7, 2010 | 08:39 AM
  #43
1979rs/z28's Avatar
Disc0monkey what kind of coupler did you use to make the 85MM maf work with the slp lid?
Old Nov 7, 2010 | 08:48 AM
  #44
ebay
3.5" 89mm 3-Ply Silicone Coupler Hose Intake Turbo Pipe
$9 just kiss the MAF to the lid they are both the same ID. trimmed around the IAT.
The way I look at it this MAF was used on every LS engine at that time but our cars, most likely because they didn't want to spend money redesigning the lid. Andrew at CSP brought up a good point that the MAFs are getting older and dirtier and doesn't hurt to freshen it up with this cheap, readily available MAF.
Old Nov 7, 2010 | 09:10 AM
  #45
1979rs/z28's Avatar
Sounds good! I'm considering trying it myself it can't hurt like you said.
Does your throttle response feel much better?
Old Nov 7, 2010 | 09:13 AM
  #46
yeah man look at the torque increase. the power is across the board. it feels like adding another lid lol
Old Nov 7, 2010 | 10:37 AM
  #47
LSxWS.6's Avatar
wow thats awesome, and the 85mm was de screend? my tuner said to leave it in, whats the power loss with a simple screen in the way?
Old Nov 7, 2010 | 10:59 AM
  #48
idk mines with out a screen and its smooth as butter but my tuner is good. if you have a massive cam with cam surge you may need the screen for added low engine speed stability. i have no issues, the screen was a big enough restriction that GM took it out of 02+ Z06s.
Old Nov 7, 2010 | 11:18 AM
  #49
LSxWS.6's Avatar
hmmm well im running a ms4 which is somewhat big, and my tuner said to leave it so mayb thats why
Old Nov 7, 2010 | 11:26 AM
  #50
djfury05's Avatar
do it before you get retuned this week wooo!
Old Nov 7, 2010 | 12:41 PM
  #51
1979rs/z28's Avatar
You read my mind
