PCV Oil Catch Can
1. Accurate has baffling - Greddy does not
2. Accurate has lines in the cylinder to keep oil from climbing the walls - Greddy does not
3. Accurate has a drain plug - Greddy does not.
You decide. I would ask that you call the shop or email them. Todd will be happy to answer any questions.
dude (it's kinda of funny when an old fart like me says "dude"), find a job in sales and retire early
BTW, Greddy uses a 15 mm hose (i like)...what's Accurate Machines' hose size. Currently, I have some ricer catch can that's maybe 3 mm at the smallest point of the intake/outlet connectors...which means not enough air flow to blow out a candle.
size does matter
take a look at this, do think its oil consumption? I had it looked at by brent at TEA, i have done a leak down test and compression tests, and its all good, but after going to WOT, and then ;etting off, it does this ****. Keep in mind that this was while the car was about 1 point too lean, but I had it tunned, but the smoke keeps comming. Some folks have told me that its just the way some LS1,s are. But i only loose about 1/4-1/2 a quart every oil change, so maybe the can will fix it.
Guys, tell me what you think
My car burnd lots of oil since Ive ownd it. When I swapped the intake there was all kinds of oil drippin out of the old intake and in the ports. It was ridiculous. I think headers make the problem worse by scavenging the intake gases. Increasing the suck on the pcv. Also drivin styles affects oil consumption from the pcv. Cruisin around just above idle probably minimizes it whereas cruizin around at 2000rpms makes it worse. This is probably why cams make it worse. They cruise smoother at higher rpms than stock.
Anyways heres a link to instructions of building a catch can by Nine Ball.
http://divetx.org/ls1info/article.php?sid=273
Im gonna make this and put it on this weekend. Hopefully this solves the oil burnin problem.
Yeah, oil in the combustion chamber is very bad because it lowers the octane ratin of fuel. If you think you have this problem and dont fix it you should probably run race gas when racing..
This is a cheap can that nine ball is showing, but I would much rather have a can that looks good, stock and yet is functionally better. This can will not take a lot of pressure as the accurate machines can.
You guys keep saying that headers CAUSE the problem. A PCV system use the motors vacuum to pull air out of the crankcase. With headers, you have a more volume through rpms therefor pulling more air. More air flow will pic more moisture. The problem still is not headers, but the pcv system and how it draws air.
Grant
I will tell you that the hose size is plenty on this setup. I can pull the hose off and you could use it as a vaccum cleaner.
That said, I was very impressed with the time he spent answering my questions. Additionally, he is willing to modify my can with larger connectors to accomadate a bigger hose...AT NO CHARGE. Is this a dream, if so don't wake me up.
As far as sponsoring this board, he is working with sponsors to sell this product.
Thanks Grant for the comparo
I AGREE!
Also new hose connectors to match can and not the brass ones .
Sounds like the catch can of choice.
I have one ordered and he said as soon as the new connectors are out he will send them to his customers.
Great service........
We can all say "
" to Todd!!
I have to say this for Todd.... He is very helpful and answers all your questions. I have emailed him alot and he always gets right back to me. His cans are an awesome design and many colors to boot! Im ordering mine today!
-Mike
We can all say "
" to Todd!!
from a quality/funtional standpoint there's nothing close that i've seen. Like wise i cancelled my GRaddy for the the AMC and glad i did Thanks!
I received it very fast after I sent the PayPal payment to him. IMHO, the best can out there!
-Mike
