PCV Oil Catch Can
Old Feb 5, 2004 | 02:11 PM
  #41
cueball's Avatar
Originally Posted by BlackHawk131
Very very nice item. I have had mine for about a year and these things work great. They have worked on ANY type of car. I get about a 1/4 cup of oil about ever 3000 miles. This item keeps that crap from returning to the combustion chamber. If you have questions, please email me and I can send pictures and info.
This attactment is a prototype. I will update with my polished can later tonight.
those look nice, where can you get that oil catch can, and how much
thanks
Old Feb 5, 2004 | 04:11 PM
  #42
HotRod68Camaro's Avatar
Originally Posted by RPM WS6
There’s really nothing to take any pics of on the inside of the Greddy. It’s just a regular container, nothing to look at on the inside except 4 walls. I’m not really convinced that baffles would make any difference in doing it’s job. I guess they couldn’t hurt though.
Seriously, there’s nothing wrong with talking well about an item you like and introducing it to the rest of us. Hell, actually I think your catch can looks great as well and would probably consider buying one if I ever wanted to replace my Greddy, especially if the manufacturer becomes a board sponsor. My only issue was, that you came on here and started bashing the Greddy can (making false claims about it’s quality) that works great for most everyone that’s used it. I just don’t think you need to bash one item to promote another, IMO.
I do agree though, that the hoses supplied with the Greddy are not very good, but it really wouldn’t have mattered to me what hose it came with, because I needed about 6 feet of line each way to mount it where I wanted and I doubt any of the catch cans come with 12 feet of line anyway. Either way I’d have to supply my own line in my application.
If you could, please PM me the price on this can. I may be interested in using it for another car.
so what kind of line did you use? personally i think that braided steel would trick buti not sure if id be able to mount it to either GReddy of BlackHawks tanks
Old Feb 5, 2004 | 06:20 PM
  #43
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
BlackHawk131... thanks for the PM. I will think about it.
I may be moving my Greddy can to another one of my cars because I think it would fit perfect on that car, due to the square design. If I do that, then my T/A will need a new can.
Is there any way you can post some more pics of how & where you mounted it? Thanks.
Old Feb 5, 2004 | 06:23 PM
  #44
RPM WS6's Avatar
I used fuel line, 3/8" I beleive.
Old Feb 6, 2004 | 12:00 PM
  #45
BlackHawk131's Avatar
Restricted User
There are 2 holes on the back of the clamp that I screwed directly into the Lower air box assem. that covers the radiator and fans, directly infront of the power steering pump. Remember that this can in this picture was polished by myself. This is not how the clears will look.
Old Feb 11, 2004 | 12:04 AM
  #46
white01ss's Avatar
Default AMW Catch Can Installed
It's been a few days now since I installed the Accurate Machine Works Catch Can and I can say that I'm pretty pleased so far. I thought real hard on where to put the darn thing... Let's see - it so small it can go behind the driver's side radiator, behind the passenger headlight, where the traction control would go, on the driver's side of the radiator, and other places if you have more ingenuity.
Ultimately, I opted to make a five inch aluminum bracket and mount it directly to the passenger-side cylinder head. There's lot's of room there and it looks fairly stock, expect for the shiny brass fittings that should fade in time. I just love how short the lines need to be. I think I only used 10 inches of the many feet of hose that was supplied. Here's a few pics. Sweet Huh?
Attached Thumbnails PCV Oil Catch Can-114_1442.jpg   PCV Oil Catch Can-114_1444.jpg
Old Feb 11, 2004 | 03:33 AM
  #47
Inspector12's Avatar
TT-TECH Veteran
White01ss,
Looks good I just have one question. I don't see any headers or anything? Everyone I've talked to didn't start loosing oil until headers or cam or both were installed. Are you just doing it before hand? Or were you loosing oil in stock form? I've had a few LS1's and have never lost oil in stock form that is why I am asking. I like your mounting location.
Old Feb 11, 2004 | 04:32 AM
  #48
Snake Eater's Avatar
Hey my 2000 had about 4500 miles on the last oil change (yea I know thats bad) and it was almost 2.5 quarts low. Will a catch can help prevent this, besides changing the oil.
Old Feb 11, 2004 | 05:49 AM
  #49
TaTommyWS6's Avatar
No, it will not prevent you from losing oil, but it will prevent it from getting sucked back into your intake if it is the PCV that is causing your consumption. (In which case you will be draining that can pretty often!)
But I bet you are burning some oil also (oil rings)...
Tommy
Old Feb 11, 2004 | 06:04 AM
  #50
DARK AGE 53's Avatar
white01ss, can you post a picture of the backside of the bracket? Thanks
Old Feb 11, 2004 | 06:11 AM
  #51
David901's Avatar
Just read this thread. How much are each of these catch cans and where do I get them? Sounds like they both do a good job.
Old Feb 11, 2004 | 09:38 AM
  #52
Restricted User
Originally Posted by Inspector12
White01ss,
If you think the headers is the problem, you are way wrong. Don't be fooled by someone telling you that kind of crap. This is a problem on all with a pcv.
Old Feb 11, 2004 | 09:43 AM
  #53
TaTommyWS6's Avatar
It is 100% true that it IS a problem with the PCV, but the engine, as a system, seems often to have more trouble with the PCV after installing headers...
Tommy
Old Feb 11, 2004 | 10:06 AM
  #54
Restricted User
I personally don't believe that at all! No connection!
That almost sounds
Old Feb 11, 2004 | 10:13 AM
  #55
TaTommyWS6's Avatar
I don't believe that at all, except for the fact that headers allow more air to leave the intake track which then could pull more vacuum from the pcv in which it picks up more moisture. So I can see that it is possible, but it is not the headers that is the problem, it is the pcv system.
Old Feb 12, 2004 | 01:31 AM
  #56
white01ss's Avatar
The only way I know of to see if your engine is passing oil through the PCV is to have one of these types of devices in place. I did check it tonight and it was bone dry so far after 40 miles with nearly no full throttle action because it's been raining so much. Either way, I expect to see something in there after a few thousand miles.
As far as headers go, I have no idea if they can make the problem worse. I would think lots of WOT would be the biggest factor since that's when blow by gases are going to pressurize the crankcase. If you were to cap off those valve cover breathers the pressure build up would blow out the gaskets which would cause oil leaks galore.
Lots of cars from the sixties and earlier would just vent from the valve cover through a breather, but that's not very enviromentally friendly since that's hot exhaust bypassing the cats.
Here's some zoomed in pics of the front and back of the bracket. That big wad of aluminum is a bunch of washers and nuts wrapped in aluminum tape I used to keep the bracket level in case the 10mm bolt becomes loose. It rests on the lip of the valve cover. It'll do for now.
Attached Thumbnails PCV Oil Catch Can-114_1454_r1.jpg   PCV Oil Catch Can-114_1455.jpg
Old Feb 12, 2004 | 02:50 AM
  #57
TT-TECH Veteran
Wel I know for a fact that a cam depending on the specs ETC... can and will change the amount of vacum a motor will pull, so I am thinking that with the headers it is sorta the samething. They flow better than the stock manifolds so the engine pull more air into the chamber creating more vacum especially under hard acceleration. Now I know I did not explain that right but maybe you get what I am trying to say? More vacum on the intake will pull more through the PVC system with more oil ETC... Not my best explaination but it is 3 am and I am tired.
Old Feb 12, 2004 | 06:00 AM
  #58
TaTommyWS6's Avatar
That almost sounds
This is not rocket science, voodoo, or a homosexually influenced theory... This is FACT.
There used to be polls on this site about this very issue and most people who had oil consumption/smoke at WOT started to experience it a lot worse after headers and/or cam swap. It is far from coincidence, it is in fact a real issue.
Believe what you want, what do I care, but don't make blanket statements when you don't understand the facts. There is enough misinformation on these boards already.
I'm done....
Tommy
Old Feb 12, 2004 | 06:55 AM
  #59
JohnnyStorm's Avatar
Right on Tommy! Do you think $88.50 is worth it for a can? I can only imagine how much the Greddy was! This must be the GM price I was quoted or someone is getting serious kickbacks from this product. Just my 2 cents.
Old Feb 12, 2004 | 07:58 AM
  #60
TaTommyWS6's Avatar
This is the Greddy I bought for $99 - http://www.machv.com/groilcacan.html
There also seems to be another Greddy can for $84, but this is the first I've seen of it - http://www.300zxstore.com/greddycatchcan.html
Tommy
