How to get exotic sound
I'm still planning hopefully later next year to make my design of over the engine 180 degree headers using tri-y collectors & going 8 -4-2-1. Have decent room under a g-body cowl hood, & will take multiple steps to combat heat. Already have fender vents, will have huge hood louvers, heat shielding under hood ,Possibly heat shield over intake & valve covers, etc, twin fans running full time.
Trying to 180 cross pipes underneath for my application would be a huge mess , super hard to get equal length, & loose ground clearance.. If I didn't have normal AC location, I could cut firewall & trans tunnel for room.
Hope the sound will be worth it.
,, there were only 4 tubes to cross over, and you ran 2 behind and 2 under.. the two under crossed between the engine and trans, The old cars used to have the firewall pushed back about 6" since they were a tub&tube car that was heavily modified.Over the top exhaust is such a M***** F***** to work on in most American sedans I wouldn't even do it.. The heat and access issues make it just not worth the blood..
I'm in the middle of installing an ls1 into an E36...... and after a few beers started to look at the challenge stradale (modena exhaust), and wonder how it would sound behind the ls in the E36?
Has anyone tested an italian catback behind an ls..... any links or sound clips? Or should I just put the beer down, and go to sleep awaiting santa clause
wake up the next day and just do the normal swap cat back... magna flow etc.. etc... ??Cheers guys.
Jeff - San Antonio
If you want to hear an LS through Ferrari stock exhaust then fast forward to 14:40, saw this the other day on youtube at random
I never did complete my tri-y's to try out, so I wonder if they could really give me the sound I'm after with just one more merge. I think I shot for an even 32.5" primary length
There just seems to be a shortage of good knowledge on this subject.
My application just does not have room under the engine for 180 pipes under it, even if I ovaled the pipes, plus equal length would be hard to do & primary length would be pretty long.
Getting equal length over the engine doing a correct 180 degree merging sequence seems easier to me than it was with my tri-y's pictured..I would need to make bolt together flanges for an over the engine setup to R&R reasonably easy, so that alone would be a little more work. I feel that I could combat the heat issues with MORE extra work, but no way to know for sure other than to try.
SO, if it is possible to get the sound with my tri-y's & a merge, then no doubt that would be the easiest route to complete them & have em ceramic coated after a sound test. Plus I could one day complete & use my cross ram dual plenum intake .
The CGS c-5 that I thought was 180 headers are just equal length 4 into 1's with a very custom merge & a handmade muffler AND A bad *** big bore destroked high revving engine. Part of the deal with any good 4 into 1 headers is having the correct firing order sequence going around in a circle. Can be left or right, doesn't matter.
A Y-pipe won't give this sound unless it is at the collector like the headers above have.
180 degree headers are not equal length - in fact they're full of compromises in anything but a mid engined race car. They give a flat plane sound with unequal length primaries.
Wonder why David's are for sale now?
