Steering column help!!
Old Nov 23, 2010 | 11:24 AM
ffrh911's Avatar
Question Steering column help!!
I need to remove the steering column it's in the way of my tsp lt's!! Do I just take the two bolts out and remove it or do I really have to take the whole steering wheel out??
Old Nov 23, 2010 | 11:59 AM
ffrh911's Avatar
Someone??
Old Nov 23, 2010 | 12:01 PM
nemss1's Avatar
*remove the plastic panel under the driverside dash
*unplug the harnesses
*unbolt the bolts on the firewall
*unbolt the single bolt on the steering linkage
*unbolt the bolts to the bracket right up under the dash
Old Nov 23, 2010 | 12:04 PM
ffrh911's Avatar
Wow. How come hen I ask this in the actual exhasut thred no one can mention this??
It would hve been helpful to know this first hand. And thanks for the help! Not very discriptive but I guess I'll just start takin stuff apart
Old Nov 23, 2010 | 03:14 PM
sscamaroburn02's Avatar
what car is this on? you shouldn't have to remove the steering column???
Old Nov 23, 2010 | 07:14 PM
ffrh911's Avatar
2000 trans am. You have to remove the column. Aparently everyone has a complete different answer.
Old Nov 23, 2010 | 07:50 PM
joecar's Avatar
Can't you just remove the pinch bolt to disconnect the steering shaft from the steering gear box...?
[ i.e. in the engine bay only ]
Old Nov 23, 2010 | 08:40 PM
Titanws6's Avatar
Exactly, I wouldnt see the need to remove the whole thing, just piece in the middle with the two bolts. Thats what I had to remove on my '00 Bird to get my LTs in as well.
 Michael S. Palmer
Old Nov 24, 2010 | 08:11 AM
weird I didnt have to remove anything when I installed mine.
Old Nov 24, 2010 | 08:12 AM
but mine was on a camaro so maybe they are different
Old Nov 24, 2010 | 09:52 AM
ffrh911's Avatar
That's all I needed to know. I will try it again.
Old Nov 24, 2010 | 11:39 AM
Sales2@Texas-speed's Avatar
LS1Tech Premium Sponsor
DO NOT remove the entire column assembly!!! There is a single bolt near the bottom of that shaft where it connects to the rack & pinion and once you remove it, with a little effort, you will disconnect the two and lay the shaft to the side a bit and that'll be all the room you need in regards to the column!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old Nov 24, 2010 | 01:54 PM
ffrh911's Avatar
Ok I'm here right now. Have both bolts removed. Which side comes out first top or bottom? Do I need to let all the PS fluid out? Thanks!
Old Nov 24, 2010 | 01:59 PM
ffrh911's Avatar
Got it! Headers goin in!
Old Nov 24, 2010 | 04:02 PM
joecar's Avatar
Follow the simplest path, bro. Let us know how you go.
