SLP lid and MAF a restriction?
Old Nov 25, 2010 | 11:34 AM
jt76's Avatar
Default SLP lid and MAF a restriction?
Currently i am running the standard run of the mill SLP airlid and stock GM maf.
I am in the process of changing my setup and it will consist of the following:
Trick Flow 215 cyl heads, a cam in the high 230's = low 240's and a FAST 90/90.
SHould i upgrade to the larger FTP lid and larger MAF? Speed density is also an option and eliminate the MAF completly. I dont want any choke points in my intake path.
thanks!
Old Nov 25, 2010 | 11:49 AM
jimmyblue's Avatar
Moderator
Lid, not a restriction. Screened MAF, yes. If you're ready to
throw that kind of money and presumably tuning at it, go
look for an open MAF of appropriate diameter. Preferably one
with a known cal curve to start from, preferably one near
the stocker. I don't think you'll max it out NA. Though big
cam may drive it slightly nuts at the low end.
