why is my car doing this??
Old Dec 2, 2010 | 05:57 PM
crazyelf's Avatar
Default why is my car doing this??
For the past week or so my idle has been hanging around 1k when I come to a stop and it takes it a few seconds before it comes down to normal. It doesn't do ot every time either. It also idles completely normal after a wot run.
I've had a ported throttle body on for a few months with no problems so I don't link that's it either. Could it be caused by me removing the ac belt(it was squeeking)
Old Dec 2, 2010 | 09:45 PM
DaveX's Avatar
Possibly, yes. The computer adds air when it "thinks" the a/c compressor is engaged, which could result in high idle and driveability issues since the belt has been removed. Does it do it with the hvac controls set to "off"?
Old Dec 2, 2010 | 10:04 PM
garygnu's Avatar
maybe a dirty MAF or a vacuum leak.
Old Dec 2, 2010 | 10:38 PM
crazyelf's Avatar
Yes it still does it with the climate control off. And I cleaned the maf already and sprayed carb cleaner everywhere looking for a leak. The pcv line that goes around the back was already replaced a while ago.
Old Dec 2, 2010 | 11:45 PM
CamaroZ28_LS1's Avatar
The TPS can cause a hanging idle. I have seen that before on a few of my friends F-Bodies.
Old Dec 3, 2010 | 01:08 PM
Head Hunter's Avatar
Have you checked the IAC?
Old Dec 3, 2010 | 02:24 PM
crazyelf's Avatar
IAC is pretty new, but im going to hook it to a scanner today and check the counts anyways. Im thinking it may be a TPS thing because everytime I go WOT it clears up for some reason.
Old Dec 3, 2010 | 02:46 PM
bayer-z28's Avatar
Mine does that too.. It's fine after it gets its "fix." It just wants WOT.. It's got the typical LS* personality.
At least that's how I justify it. It's tuned and been doing it since I did the H/C/tune.
